Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 02-10-2008, 02:20 PM   #1 (permalink)
Default Need Some Info On VPN..Please
I just Downloaded a VPN "Hamachi" free version, I want to know what VPN really do ??
through VPN i will be safe from hackerz ??
How can i know Mine VPN is working fine ?? I seen mine ip remains same as before not using VPN..
here is Screenshot of the VPn..See
through using Is Mine Net will bcom Slow??
Pearl Groupz is offline
Old 02-10-2008, 02:26 PM   #2 (permalink)
hullap's Avatar
Default Re: Need Some Info On VPN..Please
thumbnails please
hullap is offline
Old 02-10-2008, 02:53 PM   #3 (permalink)
The Black Waltz
What Hamachi does is set up a virtual static IP address for you. Through this, you can play games with others using your net connection. Hamachi is quite secure enough. And I don't think your net connection will be slowed down.
#krow @ irc.freenode.net
Cool Joe is offline
Old 02-10-2008, 04:41 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ All that, and you can connect to several networks, so it makes the OS think that you're a part of several LANs, so gaming and file sharing is made very simple, its just like in a lan.
If you want anomymity over internet using VPN, go for TOR.
dheeraj_kumar is offline
Old 02-10-2008, 07:15 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
[Offtopic]
There's a difference between "mine" and "my". Both words are used differently in different scenarios. In your post, the correct word to use is "my" instead of "mine". I'm sorry to nitpick, but this is kinda irritating
[/Offtopic]
kalpik is online now
Old 02-10-2008, 07:22 PM   #6 (permalink)
The Black Waltz
^Yep, I've seen some guys doin that mistake.
Cool Joe is offline
Old 03-10-2008, 07:35 AM   #7 (permalink)
i just want to ask that mine net activities will be safe or not ?? means no one knows what i am doing..??
Old 03-10-2008, 10:45 AM   #8 (permalink)
The Black Waltz
You're safe.
Cool Joe is offline
info.exe valtea QnA (read only) 6 24-09-2007 05:52 PM
Need Info abt PHP nareshwithu Open Source 14 17-05-2007 03:08 PM
RAM Info please... shariq_pj Hardware Q&A 4 13-11-2005 06:43 PM
- by bhaskar
