Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 25-09-2008, 09:02 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Default converting mp3 to ogg/aac increases quality ?
Hi
I have iriver clix 2 and just got seinheisser CX300 earphones
They are gud ..but not so excellent..i overexpected may be..
now my q is that if i convert an mp3 song to ogg or aac ..and play it in iriver will sound quality will be amazingly good or no diff at all
esumitkumar is offline
Old 25-09-2008, 09:06 PM   #2 (permalink)
Default Re: converting mp3 to ogg/aac increases quality ?
both are lossy, no way you can get better sound quality.
Faun is offline
Old 25-09-2008, 09:12 PM   #3 (permalink)
MP3 which has 96KBIT/s bitrate is good enough, I actually find it better than 96KBIT/s bitrate AAC.
Xccentricity is offline
Old 26-09-2008, 09:12 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Well, the rule of the thumb in any conversion is - you can never get more quality than the source you used.
dheeraj_kumar is offline
Old 26-09-2008, 09:59 PM   #5 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^You get lesser quality whenever the source is lossy.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 26-09-2008, 10:10 PM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
When the song was compressed to mp3 initially, a lot of detail was lost which is how the file size got smaller. Now that detail is lost forever and cannot be regained. Some softwares claim to regain lost compression details but most often they just boost certain frequencies.
Now when you convert that mp3 file to another format, unless the conversion is lossless, you are going to LOSE EVEN MORE details. So no matter what format you use, whether it is aac or ogg, it'll be worse than the previous version.
aac and ogg are superior to mp3 only when you directly compress the original source, say, an audio cd to these formats. But if you convert an already compressed mp3 to these formats you won't get better quality. In fact it gets worse. So just let it be in the mp3 format.
As for the CX300 allow them to break-in. Some speakers need to be broken-in for them to perform optimally. Connect the earphones to a source, turn the volume upto 80% and let them play for some time continuously (like an hour or two). See if there is any difference in the sound. The bass will definitely be deeper as the drivers will lose their initial stiffness and will move more freely, thus moving more air.
Btw, how much did you get the CX300 for?
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
DoT Increases 3G Allocation Pat Technology News 6 30-07-2008 01:01 PM
CPU usage increases to 100% when using TurboC Shikhar CPU / Motherboards 10 27-06-2008 10:36 PM
Firefox - does it increases memory need as time goes? eagercyber Software Q&A 7 18-01-2008 12:39 PM
converting realplayer youtube vids to high quality Batistabomb Software Q&A 3 11-12-2007 08:15 PM
Tformat - increases the life of floppies Ramakrishnan QnA (read only) 7 06-05-2006 06:58 PM
- by bhaskar
