Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 12-09-2008, 08:40 AM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default Sweet sweet illusion( 56k warning)
I have seen quite a few optical illusions on the net, and this has to be the best! My mummy thought that I wa pulling her leg.
I have excluded the explanation that came with illusion on purpose to make it lil more fun. I'll post the source later.
If you don't see the illusion.. look away
Edit:
Source
If you look at the spinning girl's silhouette below, you will think it is spinning clockwise, probably. When you check her shadow below, momentarily the spinning direction changes in your mind, and now the girl is spinning counter-clockwise. It can be quite hard at the beginning to notice switch of the spinning direction, but eventually you'll manage.
It took me forever to change her direction. The trick was not to try too hard..
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 12-09-2008, 09:45 AM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Sweet sweet illusion( 56k warning)
This one is old. s18000rpm posted this long back. And anyways I can make her spin in any direction I want.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 13-09-2008, 12:10 AM   #3 (permalink)
nix
Senior Member
nix's Avatar
now i didnt really get the illusion.. though i know it changes directions every few seconds...
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 13-09-2008, 01:23 AM   #4 (permalink)
chesss's Avatar
^now its how ur brain percieves the image. The image itself never changes.
Edited first post with source..
chesss is offline
Old 13-09-2008, 02:23 AM   #5 (permalink)
clmlbx's Avatar
image changes
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline
Old 13-09-2008, 10:15 AM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
Yup. The image itself is not spinning clockwise or anti-clockwise. It is actually just oscillating from left to right and back again. It's our mind that thinks that she is rotating.
To make her spin in any direction you want simply look at her foot which is higher up in the air (the other is pointing straight at the ground). When the higher foot coincides with the foot pointing down, it depends upon you as to how you want it to come out from the other side. You can either imagine the higher leg to come around from behind her lower leg, or from the front of her lower leg. If you imagine the higher leg to come out from behind once and from the front the next time, like most people do, you'll find that she is rotating. But everytime it coincides, if you imagine it to come out from either behind or just the front without alternating everytime, then you'll see that she just oscillates from left to right without actually spinning. I know it is difficult to understand what I am saying, but after a while you'll figure out yourself.
Prasad Naik
krazzy is offline
Illusion Krazzy Warrior Chit-Chat 24 28-04-2008 08:38 PM
The perfect & sweet HTPC configuration gxsaurav PC Components / Configurations 2 21-03-2008 10:17 PM
Ohm sweet Ohm: Linux versus Vista smart homes Cyrus_the_virus Chit-Chat 1 12-03-2008 07:22 AM
Sweet Child'O Mine (Indian Version) Hitboxx Chit-Chat 1 07-01-2008 10:12 AM
Review: The Sweet Agony That Is Nokia N81 aryayush Mobiles and Tablets 15 14-11-2007 12:36 PM
- by bhaskar
