Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 10-08-2008, 11:50 AM   #1 (permalink)
_______'s Avatar
Default Security System for Home
Hello everyone, I'm constructing a new house in Chennai and planning to install some security equipments at home like DVR System. Can you please suggest ideas and what all can be installed for home security ?
Budget: 30k.
Thanks in advance.
_______ is offline
Old 10-08-2008, 04:11 PM   #2 (permalink)
Default Re: Security System for Home
Hi _______,
I like your User ID
Is 30K budget only for the security system or for the entire setup (PC, display, etc.).
What have you got at hand? Do you already have a PC. What kind of surveillance system do you plan to build? - PC based / DVR / display based? Exterior / Interior surveillance?
I do not have any such system. Neither do I have any first hand experience in building it myself. I do not know the availability of products in India for this purpose, but you sure should get these in India.
If a PC based system, all you will need is a camera or two (depending upon your requirement), a PCI DVR Card and disk space. I guess it would be 1MB per minute of video (may be 1.5MB for audio+video) for an acceptable quality video (like 10fps). The setup should be pretty simple. Plug the camera phono cables into the PCI card. You should get software with the PCI card that will help you record / monitor / schedule. These software also allow you to setup a web server and monitor your cams remotely.
If I look up these systems in Europe, I see that a fine decent Sony sensor based tiny camera (0.5 LUX) costs about 35€ (2250 INR), PCI card to support upto 4 video cameras and 1 audio channel for about 120€ (7700 INR).
Research before shopping for these equipments. For example, find out how much of minimum LUX camera you will need to monitor the desired area.
Your best bet is to ask local PC hardware vendors for these equipments.
Do keep us informed about your findings. In case you setup a surveillance system, do post a tutorial / how-to for others.
Regards,
Bandu.
Bandu is offline
best home speaker system under 10k? beanstalk_230 Audio 2 08-11-2007 10:19 AM
Security cam for home ramborums QnA (read only) 4 28-08-2007 06:20 PM
system security varunprabhakar Software Q&A 14 04-02-2007 04:26 PM
Home threatre system shyamno QnA (read only) 6 11-10-2006 02:09 AM
Room security system vedant_15 QnA (read only) 6 01-09-2004 09:03 PM
- by Jripper
- by kool
- by kool
