I don't know if this is the right section to post this, like I really care, but is there a way to bookmark threads so I can refer to them whenever I login?
What I meant was, is there an option on the site itself to bookmark certain posts? If there isn't then I think digit shud keep such an option as it's a big headache for forum members to keep track of posts. Also the search feature doesn't always take u to required page, instead it just gives u the link to the beginning of the thread. U have to go thru each and every page of the thread just to find what u r looking for.
right click on the number at the right end of the post title
Yeah thats ok but what if I wanted to track certain threads? For eg after I login, when I goto User CP it shud show me an option where I can bookmark certain threads which I wish to follow, rather than creating bookmarks on my browser.
tht is what 18000 said, when u subscribe to a particular thread or reply in it, it will show in ur UCP on the front page if there is a new post in the corresponding thread
like if u go to ur UCP now u should see this thread there
I think I asked a very stupid question. But what really troubles me is, whenever I'm trying to find a particular section in a thread. When I do a search for it using certain keywords, it does bring up the search results but it only gives me links to the beginning of the thread not to the section itself. So I have to go thru each and every page of the thread to come to the right section.
^^ There is an option to Show Results as : Posts in Search page. If you select Posts instead of Threads (default) you'll get all the posts you are looking for which you can click and open ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
