04-05-2008, 01:41 PM
Got problem with Car windshiled need help
I got some stains on my windshield , experts says it caused by borewell water washing , i have been cleaning my car with bore well water ever since i bought it .
Driving at Rainy nights is impossible to me , can this stains be removed ?from the glass , would thinner work ? ?
monsoons are soon approaching , i am scared driving at night with that stains on .
please help me with a solution
dont know if this question is fit for this forums
04-05-2008, 02:07 PM
Re: Got problem with Car windshiled need help
try cleaning it with harpic or easy off bang
04-05-2008, 02:09 PM
Harpic ? ? Toilet cleaner ? ? I ll try easy of bang right now and will post the reports
04-05-2008, 02:15 PM
try it at ur own risk tho
both r pretty strong cleaning agents - will not be held responsible if your windshield suddenly turns into gooey blubber
04-05-2008, 02:16 PM
collin the glass cleaner or acetone
Beware test a small area probably at the bottom right or left of windshield to see if any side effects are there in case of strong agents
04-05-2008, 02:36 PM
left this forum longback
windshield cleaners are available in car deco shops  use one!
04-05-2008, 03:58 PM
Tried several including amway , none worked , wanted to know if any one have similar experience and cleared the glass without harming the glass
04-05-2008, 04:21 PM
^well,what about car shampoo's then?most of these stains will be cleared by these shampoos
04-05-2008, 04:23 PM
Evolving Rapidly...
well, if its due to borewell water. IMO stains will not be permanent.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
04-05-2008, 07:33 PM
I am planning to use thinner but that can remove the paint too ..need to be extra careful when using it , but not sure if that would work BTW what is IMO stains ?
04-05-2008, 07:48 PM
thinner imo contains acetone so beware of dissolving any organic artifact with it
I remember an instance in which my classmate stuck a tattoo to a friend on forehead...lol....and then he tried and tried but in vain...finally i got an idea and we went to chemistry lab...where the attendant used acetone to remove that away in a jiffy
04-05-2008, 08:29 PM
Evolving Rapidly...
i meant to write "in my opinion, stains will not be permanent".
coz its most probably just salt deposition.
05-05-2008, 10:02 AM
Legen-wait for it-dary!
^^Wrong section, post under Hardware Troubleshooting.
LOL! jk. You can try acetone. My friend and me played with it on cleaning stains.
05-05-2008, 10:20 AM
Caballero de Real Madrid
This may bit weird.....
Try newspapaer....yeas newspaper....and rub it dry..then just use plain water....try mineral water....heard this when i was in college..our college bus drivers did this....
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
05-05-2008, 01:36 PM
The Thread Killer >:)
I would suggest you not use thinner. Then, it'll be translucent  or a thick plastic piece
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
05-05-2008, 01:47 PM
Tribal Boy
Please do not think I am advertising or spaming, I am no way related to this site.
http://www.indiacar.com
Its good for everything related to cars including advise, expert opinion etc. You can try posting this in their message board.
05-05-2008, 01:59 PM
^^u r an old respected member
08-05-2008, 07:43 AM
Originally Posted by T159
 Poor guy , or else he would have to carry it for rest of his life
news paper with black print in it are excellent clearners , actually the best in removing oily left out not removing these kind of stains
finally i ll have to use thinner or better take my car to the painter
the best advise i got from the car manufacturers is that i need to change windshield
Reason: Automerged Doublepost
08-05-2008, 10:16 AM
#19 (permalink)
Stay Silent!
Best thing to do for the windshield? Just pour a sachet of glass cleaner shampoo, sold under the Maruti brand, into the water compartment (the one used to spray water on the windshield )
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
08-05-2008, 01:28 PM
#20 (permalink)
a_g = JPKN
can you post a pic of your car's windscreen?
ASUS K53SV SX520D + BF3
08-05-2008, 01:50 PM
#21 (permalink)
have u tried coke(very good for removing stains).
A computer once beat me at chess, but it was no match for me at kick boxing.
09-05-2008, 11:03 PM
#22 (permalink)
mekalodu
hey ... chk if the below link helps ....
http://www.ehow.com/tips_17643.html
change the windshield?? u will do that every summer???
mekalodu
10-05-2008, 07:07 AM
#23 (permalink)
sure dude , my friend is coming home with his camera for next update for our web page , so will get a pic with that cam it self , cos it need close observation to get noticed , but during rain at night u will get to know in no time
10-05-2008, 07:17 AM
#24 (permalink)
none works , trying diffrent brands from last monsoon , i survived last rainy night , not sure abt this season if things remain same  for safety either windshield or stains get replaced
Naaa not tried so far  If it can clear the stains ill uplaod the video of me cleaning the windshiled
Originally Posted by iinfi
This summer i mihgt need to change the wind shield if that stains remain
