Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 27-04-2008, 01:58 PM   #1 (permalink)
pirates1323's Avatar
Default Smps 600w ... where to put UPS plug ?
hey I m going to upgrade my SMPS from 300W to coolermaster SMPS 600W ... and Geforce8800GT ... RAM 2GBDDR2 800MHZ ... 1GB already installed ... So after installin these ... will the computer power load will be higher ? ... where should I put the UPS plug in the normal switch or power plug(AC one) ??/ ... im confused lol
pirates1323 is offline
Old 27-04-2008, 02:14 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Smps 600w ... where to put UPS plug ?
The normal 5 Amps socket will do, you are running a PC, not an AC. It is not only the Amperage of the power socket that matters but the gauge of the wire that connects it to the meter.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-04-2008, 03:16 PM   #3 (permalink)
I though cuz of 600w smps it would need more power supply... moreover its geforce 8800GT .. and i also got 2 sata hdd ...
SMPS with 24+4 pin bhoolkumehul Hardware Q&A 3 25-06-2007 06:14 PM
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
