| Forum |
| Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here |
#1 (permalink) |
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard |
#2 (permalink) |
The Devil's Advocate
OGen or Hitachi
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#4 (permalink) |
no idea but OGen (O-General) and Hitachi are the costly ones, with performance at par but much better than the rest (samsung/lg etc) and at a rate higher than the rest
#6 (permalink) |
BlackBerry Guru ! :)
Best is Daikin ... but it wud cost u a whopping 35 K for 2.0 ton .. otherwise , i wud recommend u to go for electrolux , hitachi or carrier either !
Username Changed - BlackBerry7100g To BBThumbHealer ! |
#9 (permalink) |
I think...all above cost too much ....
Among... Samsung\LG\Onida\Whirlpool....which one is best ?
#10 (permalink) |
MVP in VC++
First of all first what is your room dimension? If it is around 150sqft, then 1.0 Ton is fair enough...
Always I would suggest you to go for 5 star rated AC as it saves you a lot of current and audacity level will be low. Out of LG/Samsung/Onida/Whirlpool, I think the LG Pearl AC is somewhat good..Look at the following link http://www.in.lge.com/Product/Produc...8&subcat=Split |
#11 (permalink) |
i have samsung and i would recommend you not to go for it. it is about an year old (1 year warranty over) the gas leaked because it apparently uses a copper wire which should not be used for ACs not to leak gas, i was told this by the guy who came to re-fit the AC, he was on samsung's behalf, onida and whirlpool would be my next options if i were u, no appraent reasons but the brand
#12 (permalink) |
ogen hitachi daikin upmarket brands...blue stra carrier blue star lower rungs..its not summer yet..is it..w..where r u australia?..
---------- Post added at 06:46 PM ---------- Previous post was at 06:46 PM ---------- ...voltas..among lower rung |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| split .mkv files | temperworld | QnA (read only) | 6 | 13-12-2007 06:57 PM |
| Split in Apple maybe!!! | iMav | Technology News | 11 | 29-10-2007 10:44 PM |
| How to Split GAME DVD in CD ??? | almighty | Gamerz | 3 | 21-09-2007 11:40 PM |
| Split RAR archives... | REY619 | QnA (read only) | 2 | 06-08-2007 11:37 AM |
| Suggest a Split AC | planetcall | QnA (read only) | 1 | 03-04-2007 10:17 AM |
