Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 18-02-2008, 11:38 PM   #1 (permalink)
Default help!!!!os messed up
hey i just used a pen drive of a frenz o mine..i inserted it in my comp after takin wat i wantd frm his lap d files transferred properly but wen did it again to transfer other files before pluggin it it in my pc restarted...then i tried loggin in again it accepted my user n pass but then when the loadin your settings box appeared,soon after that the saving your settings appeared n then returns to the logon screen,..
dunno watta do..
plss help..
artem is offline
Old 19-02-2008, 01:25 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: help!!!!os messed up
i think your system has been infected with a virus. Although i dont know the exact method of recovery from this one, you can try this:
Try logging into the default Administrator account. TO do that press ctrl+alt+delete twice on login screen. In the login window that comes up type Administrator as username and password that you setup at the time of windows installation, if you didn't then leave it blank.
if you can login to this account, just delete your previous account and setup a new one.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 19-02-2008, 09:47 AM   #3 (permalink)
High without substance...
chicha's Avatar
ctr+alt+del will work only on XP professional and not on XP Home.
what you can do is, if you have a good antivirus like NOD32 etc, restart your pc and safe boot it, run the whole system scan. you may have to udate your virus signature before scanning.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 19-02-2008, 10:28 AM   #4 (permalink)
Thanks, i was not aware of that. waise, he hasn't mentioned that he is using XP home.
Old 19-02-2008, 12:51 PM   #5 (permalink)
hey i have Win Xp PRo SP2
i tried that already it isnt workin,,,
i tried the safe boot earlier but the same thing is coming up..
its prob a virus only is there any other way to get rid of this problemo???
artem is offline
Old 19-02-2008, 04:35 PM   #6 (permalink)
you cannot even boot into safe mode with command prompt??
Old 19-02-2008, 07:16 PM   #7 (permalink)
chicha's Avatar
no offence to you. thats why i mentioned.
chicha is offline
Old 21-02-2008, 10:40 PM   #8 (permalink)
hey me jus formatted my system thou if any one could tell me the xact problemo
artem is offline
Old 21-02-2008, 10:48 PM   #9 (permalink)
The Unknown's Avatar
WRONG SECTION!!!!!!! MUST GO IN QnA OR S/W TROUBLESHOOTING
KDE on ArchLinux
The Unknown is offline
Computer Messed Up! How to go about fixing it? hitman050 QnA (read only) 5 01-05-2007 10:15 PM
Messed up monitor settings and no X phreak0ut Open Source 8 28-03-2007 10:15 PM
msi messed it up ASH18MARCH QnA (read only) 3 24-07-2005 11:49 AM
Messed up while partitioning!Pls help. harpoon QnA (read only) 4 05-09-2004 07:14 PM
- by kool
- by kool
- by kool
