Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 27-10-2007, 10:20 PM   #1 (permalink)
clmlbx's Avatar
Default What Does MINIMUM REQUIREMENTS MEANS ?
minimum requirements :-
I am little confused here .
ok for example
minimum reqirements to play this game is :-
2.8 ghz proccy
512 mb ram
1.2 gb hard-disk
so now if I have core2duo 1.7 ghz
and 256 mb ddr2
so
means how de we know ...........
what is minimum requirements
p4 2.8 ghz proccy or core2duo 2.8 ghz proccy
512 mb ddr ram or 512 mb ddr2 ram
little confused .
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 27-10-2007, 10:22 PM   #2 (permalink)
Cool G5's Avatar
Default Re: What Does MINIMUM REQUIREMENTS MEANS ?
Which game???
It should be P4 & DDR ram definately.
Cool G5 is offline
Old 27-10-2007, 10:26 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
Even if one of your component is below the minimum requirement,you won't be able to enjoy the game the way developers meant it to be...But never go on minimum requirements alone while deciding upon a game.Always check out the demo of that game on your PC before getting it.
Life is as complicated as you say it is.
shady_inc is offline
vps-what does it means? kerthivasan QnA (read only) 4 26-02-2007 03:54 PM
Hitman 4 minimum requirements executioner Gamerz 13 16-10-2006 11:53 PM
What does this means? hluachawngthu QnA (read only) 1 11-06-2006 10:51 PM
List/Site/Tool for knowing Minimum Game Requirements? GameAddict Gamerz 6 28-04-2005 11:48 AM
- by bhaskar
- by Deepaks
