Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 03-10-2007, 06:12 PM   #1 (permalink)
Default utorent potimal settings
hello guyz i am using a 2mbps NU plan.
my actual DL speeds are 1740kbps or 217kBps
my acual UL speed 210 kbps or 26kBps.
what speeds shud i set so that i get maximum DL speed?
currently Ul-20kBps
DL-0KBps(unlimited).
please reply.
SunnyChahal is offline
Old 03-10-2007, 06:14 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: utorent potimal settings
Your settings are just fine, you'll leech at the highest possible speed of the Torrent Swarm.
QwertyManiac is offline
Old 03-10-2007, 06:16 PM   #3 (permalink)
but people say that setting DL speed to 0 hurts the download speeds.
Old 03-10-2007, 06:21 PM   #4 (permalink)
Commander in Chief
Why do you think it says "Unlimited" ? :-\
That's just a myth, what people say.
Old 03-10-2007, 06:23 PM   #5 (permalink)
so is 0 kBps Dl ok?
and 20 KBpsUl alright?
cani set it lower than that,i mean UL?
Old 03-10-2007, 06:48 PM   #6 (permalink)
Commander in Chief
20 KBps upload is just fine, on public trackers. On private trackers however, to maintain your ratios, keep it as fast as possible. But 20 is comfortable enough if you leave it seeding for a long time .. I survive on 256 kbps download and 64 kbps upload
Old 03-10-2007, 06:52 PM   #7 (permalink)
how wud be 6kBps?
some say we shud keep the DL speed 90& of the theoretical DL speed.
like i have 256kBps DL theoretically.so my DL speed sud be 230kBps.
how,s that?
Old 04-10-2007, 04:42 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
more u share\upload more DOWNLOAD speed u get .........
... W H O T ...
ax3 is offline
Old 04-10-2007, 04:47 PM   #9 (permalink)
Commander in Chief
Keeping it low will help you surf while downloading better but if your aim is to leech at the fastest rate possible, I don't see a reason why you should not set it to UL.
Settings for? kumarn_2004 Software Q&A 9 20-09-2007 09:53 PM
settings for SE P1i rakhunathan Mobiles and Tablets 1 03-09-2007 10:31 AM
!dea GPRS settings REY619 Mobiles and Tablets 3 13-07-2005 06:29 PM
C:\Documents and Settings\abc\Local Settings\temp remove it? Huzefa QnA (read only) 6 03-07-2005 10:58 PM
