| Forum |
| Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here |
#1 (permalink) |
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 . I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. In addition, Wife 1.0 installed itself into all other programs and now monitors all other system activity. Applications such as Poker Night 10.3 , Football 5.0 , Hunting and Fishing 7.5 , andRacing 3.6no longer run , crashing the system whenever selected. I can't seem to keep Wife 1.0in the background while attempting to run my favorite applications. I'm thinking about going back to Girlfriend 7.0 , but the uninstall doesn't work on Wife 1.0 . Please help! Thanks, A Troubled User. ____________ _________ _________ ________ REPLY: Dear Troubled User: This is a very common problem that men complain about. Many people upgrade from Girlfriend 7.0 to Wife 1.0 , thinking that it is just a Utilities and Entertainment program. Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run EVERYTHING !!! It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0 . It is impossible to uninstall, or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not allow this. Look in your Wife 1.0 manual under Warnings-Alimony - Child Support. I recommend that you keep Wife1.0 and work on improving the situation. I suggest installing the background application "Yes Dear" to alleviate software augmentation. The best course of action is to enter the command C:\ APOLOGIZE because ultimately you will have to give the APOLOGIZE command before the system will return to normal anyway Wife 1.0 is a great program, but it tends to be very high maintenance . Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0 ,Cook It 1.5 and Do Bills 4.2 .. However, be very careful how you use these programs. Improper use will cause the system to launch the program Nag Nag 9.5. Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 ! WARNING!!! DO NOT , under any circumstances, install Secretary With Short Skirt 3.3 .. This application is not supported by Wife1.0 and will cause irreversible damage to the operating system. Best of luck, Tech Support got this in a mail !!
Sony Ericsson Flashing, Modding, Patching, Hacking And More ! http://www.akshayy.com/sonyericsson/ Last edited by a_k_s_h_a_y; 02-09-2007 at 11:53 AM. |
#2 (permalink) |
The Devil's Advocate
this was hilarious havnt read something this hilarious in a long time ... reallly great share ...
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#4 (permalink) |
Phenom II X4 920 Owner
hilarious man......awesome stuff ... cant he upgrade from wife 1.0 to wife 2.0 beta ...
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal |
#5 (permalink) |
>:)I-):(|)8-X
awesome ..
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL |
#6 (permalink) |
left this forum longback
GF7.0 crashes the system if it detects wife1.0 already there!!so no parallels or VM
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#7 (permalink) |
Lol...just install Divorce 3.2 to remove wife 1.0 from ur system,then u can safely install girlfriend 7.0.If u want u can also dualboot wife 1.0 & girlfriend 7.0. Thank you for writing,aap ka din shubh ho.
ShutterTux - Photography, Linux & Life! : http://shuttertux.wordpress.com |
#9 (permalink) |
The G-Axe Effect
I saw it before, but hilarious indeed. One thing though...GirlFriend 7.0 is good, but after continues working in GF7.0 you will sure want to go to Wife 1.0, nothing beats that
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com |
#10 (permalink) |
>:)I-):(|)8-X
Any one using Wife 1.0 here ? They may be many with Girlfriend 7.0
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL Last edited by Charan; 02-09-2007 at 03:20 PM. |
#11 (permalink) |
M$™ Certified Spammer
nice one
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l |
#12 (permalink) | |
Security freak
Location: 01100001 01110100 00100000 01101000 01101111 01101101 01100101 00100001
Whatever you do, make sure they reside as far apart as possible...definitely on separate partitions, and preferably on different hard drives...and any communication between the two, well...just make sure they can't see each other...otherwise, BOTH may crash heh.
Linux Admin by profession. OpenBSD user by choice. |
#13 (permalink) | |
Sony Ericsson Flashing, Modding, Patching, Hacking And More ! http://www.akshayy.com/sonyericsson/ |
#17 (permalink) |
Pawned!... Beyond GODLIKE
cool thing
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach |
#19 (permalink) |
ulti post and ulti replies !!!! hoohaa.. lolll
http://www.last.fm/user/NOLFxceptMe/ http://naveendageek.blogspot.com Back after a long time. And well, EndSems screwed up as usual |
#27 (permalink) |
wheres son 1.0 or daughter 1.5
#28 (permalink) | |
dad loves daughter 1.5 very much that's why he also loves wife 1.0 also his love for daugther 1.5 is soo much that he can never think of installing spywares and viruses to wife 1.0 so that they create back doors for install of divorce 3.2 instead now all in all daugther 1.5 is an excellent communication medium to communicate with wife 1.0 and daugher 1.5 results in increase in the size of love 1.0 at any point of time
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| windows/system 32/ config/system files corrupted or missing ? | mkmkmk | Software Q&A | 9 | 02-04-2009 02:55 PM |
| Mobile for my girlfriend .. 18-20k | mohit | Buying Advice | 22 | 16-03-2006 06:19 PM |
| GroupPolicy is not apply on user and system in client system | pr@k@sh | QnA (read only) | 5 | 07-09-2005 01:41 PM |
