Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 02-06-2007, 10:45 PM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Does seperate domain name help?
hi to all
i am running a forum namely www.funisland.co.nr
as u can see .. i have been using the free .co.nr to redirect to my forum which is in 110mb.com
if i go for say a new domain with .com or .net or .us...something like that..will it increase the traffic to my site...
i tried a lot to increase but cant..can anyone help me??
and another thing is when i change to newdomain wht should i do to redirect thenew domain name to yy old one..
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 02-06-2007, 11:11 PM   #2 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
Default Re: Does seperate domain name help?
Yep.. It will definitely help t increase traffic. The same effort if you apply for a .com,.net domain that it will boost traffic. Also Search engines consider .com,.net domains than .co.nr domains.
Yes, you can redirect new domain to the existing <username>.110mb.com...
Since you have are using 110mb.com, they support domain hosting. So after getting a new domain, you will get a control panel where you have to change the nameservers to ns1.110mb.com. Or another method is set a DOMAIN FORWARDING to your URL.
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
hard_rock is offline
Old 03-06-2007, 09:15 AM   #3 (permalink)
thnks hard_rock for the reply..can u explain on the second part ..or any article where i can learn about domains..
are u using 110mb??
thnks for the reply agin..
http://funisland.110mb.com/phpBB2/index.php
this is my forum address..
if i buy a domain name..
i just want have a address like say http://www.funisland.us/forum/index.php
can this be done...
and does phpbb will have any difficulty in loacting the address..should i have to change anything in the phpbb files??
thnk in advance....
Know My Thoughts..
Old 03-06-2007, 08:01 PM   #4 (permalink)
Formerly Spashy
Sparsh007's Avatar
gr8 redirected straight to registration page
y so?
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 04-06-2007, 01:39 AM   #5 (permalink)
Salieri Family
hard_rock's Avatar
No I once used 110mb.com but got fed up with their slow ftp and no sendmail facility...
What u said can be done in two ways:
1) Set nameservers to ns1.110mb.com and in phpBB admin panel change the parameters like these (As given in phpbb2 support)
3.2.2.1: General Board Settings
Domain Name - Your domain name, as the end user will see it. For example, if your Forum Index is located at http://www.cheese.com/wheel/log/phpBB2/index.php, the domain name you should enter is www.cheese.com.
Server Port - This setting should be 80 unless you are sure it should be something else.
Script path - The path from your domain to main phpBB 2.0 files. For example, if your Forum Index is located at http://www.cheese.com/wheel/log/phpBB2/index.php, the script path you should enter is /wheel/log/phpBB2/.
2) Or set a domain forwarder to http://funisland.110mb.com/phpBB2/index.php so that when you enter funisland.us it will be
redirected to this url directly opening the above page.
No, phpbb files need not be edited to serve the purpose.
-Tommy[Mafia]
Old 04-06-2007, 11:21 AM   #6 (permalink)
I can provide u the domain name plus all the setup inst.
Contact: alcomkashmir(at)gmail(dot)com
Cig... Nature... Opposite from each other..
paradise_guy is offline
Old 04-06-2007, 04:58 PM   #7 (permalink)
The Unknown's Avatar
I can provide you a subdomain, if you want. You can PM me. But it will take time as i don't manage the domain. My Webmaster does that work. Also according to our discussion, are you ready with that?
KDE on ArchLinux
The Unknown is offline
Old 05-06-2007, 12:29 PM   #8 (permalink)
THNKS MATE..REAALY USEFUL..
i will try this out..
Know My Thoughts..
Old 06-06-2007, 04:40 PM   #9 (permalink)
You are doing this presently. redirecting .co.nr to 110mb.
KDE on ArchLinux
how to seperate voice in audio file ? assddd QnA (read only) 8 02-06-2007 04:36 PM
I need to find out how to install xp on a seperate HD on my system blazindime Tutorials 1 21-05-2007 07:44 AM
All-in-One or Seperate Printer and Scanner? jiteshbhimani Peripherals 3 17-09-2006 09:14 PM
How to seperate Voice from Songs .. krishnansurya QnA (read only) 15 16-02-2005 12:35 AM
- by bhaskar
- by Deepaks
- by Anorion
