26-05-2011, 03:45 AM
kolkata vs noida, load shedding, nios
hello friend, will you please suggest me the good place to stay,
where there is less load shedding, i need electricity whole night for using laptop.
i need to attend nios sr. secondary exam so want to stay either noida or kolkata on the basis of your suggestion.
my stay period will be around 1-2 months as i have to take tuition of math.
also specify average hotel tarrif for a normal hotel or guest house for staying 1-2 months.
Thanks..
26-05-2011, 08:08 AM
the m0nk who sold his PC!
Re: kolkata vs noida, load shedding, nios
If you consider staying in a Hotel, then why are you concerned about power cuts? Almost all hotels have power backup and CESC area has extremely low rate of power cut...as far as hotel stay cost are concerned, they vary a lot depending on the Location, and other privileges offered! You should opt for a GUEST HOUSE or PAYING GUEST...they would be cheaper than hotels and you would get good fooding, atleast better than what offered in Hotels...
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
26-05-2011, 10:21 PM
thanks sammy for your reply, paying guest seems ok if i can get separate room, but how do i search for them.
i am also expecting more replies and suggestion.
26-05-2011, 11:05 PM
Manchester United <3
Way too many power cuts in Noida these days.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
26-05-2011, 11:23 PM
Simply a DIGITian
Ya, sammy is right, CESC areas have low power cuts. If you will stay in a hotel then don't even worry about this. As sammy suggested, I'd also like to suggest for PG instead of hotels. There are many dalals(Agents) in every area. So getting information about PG wont be a problem.
So first decide in which area you'd like to stay, and then contact those agents there, they'll look for it. Generally ask at local Clubs.
Kolkata is cheap place to stay too, like PG rents, Foods, Travelling etc.
So if you want a single room, it would cost Rs. 700/- to 1000/- min. So if you can share rooms, then the price gets divided. You'll also find rooms for Rs. 500/-, but not sure about this in proper city, you may need to look little bit out of the city(remote areas) for this. Otherwise if you can afford approx Rs. 1000/- then it's ok. Generally you'll get rooms within Rs. 700/-. Actually the thing that works is, people set a price for these type of rooms, now if you stay alone you need to bear the whole rent, if you share it gets divided.
Foods are cheap too, like you can have Lunch / Dinner within Rs. 30/- - Rs. 50/- at normal hotels. Road side hotels would cost about Rs. 20/-
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
26-05-2011, 11:52 PM
127.0.0.1
I think you should stop worrying about Power Cuts  Although they do happen quite a few times , still it is not anything which would stop your laptop from working .
Kolkata is very cheap place to stay for a City , really affordable hotel rates , even more attrative rates for Lunch and dinner , as stated by krishnandu.sarkar. If the course is same in both places , Kolkata would definitely be a more peaceful place to stay.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
28-05-2011, 02:49 AM
Thank you guys for you suggestion, I am using laptop so 2 hours power cut is ok for me, i was just wondering if there is >2hours of power cut.
