Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 25-04-2011, 02:30 PM   #1 (permalink)
Smile Need desperate help: Can anyone download a driver for me?
Though I may appear new to everyone, but I was active some few months back here. I forgot all my account data so I created a new one. Now since no helpful members are left on Chip forum, I have come here with a really big hope after seeing the number of people active here.
(Proceed reading the following only if you have a 64 bit OS on your system)
What I need is the latest driver for my ATI Mobility Radeon HD 4500 GFX 'card' that's on my lappy. The latest driver, though available on the AMD website, presents me a big problem. For downloading the graphics driver meant for laptop, it is first needed to download a 1 MB utility that further downloads the main driver and also gives an option to save it on the computer. This utility works on a 64-bit system which I have on my lappy. But I can no way connect to the internet using the laptop. I visited a lot of cafes but no luck: all have 32-bit OSes so my work can't be done anywhere.
So, its my humble request for 64-bit Win 7 users to download and then upload the driver on any file host for me if your connection permits.
1. Download this 1 MB utility from AMD: http://www2.ati.com/drivers/mobile/c...4-bit_util.exe
2. Run the file, extract everything on the desktop.
3. Open the extracted folder and run "CatalystMobility" file.
4. Download the driver setup and save it and then upload it to any file host for me to download.
Waiting for help with a big hope...
nilanko is offline   Reply With Quote
Old 25-04-2011, 03:41 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Need desperate help: Can anyone download a driver for me?
hey instead of using the utility u cud get the driver from other 3rd party sites...
just try google & u will definitely get the driver
Old 25-04-2011, 06:32 PM   #3 (permalink)
Available only for desktops and not for notebooks. Drivers are different for both. I tried installing the desktop driver but I couldn't.
Old 25-04-2011, 06:36 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
Its obvious so cant use a desktop driver in Laptop.
Btw how much is the size of driver download?
Well I dnt have any upload accounts(sendspace,mediafire etc).
Perhaps other users who has accounts wud help u....
goodluck
Old 25-04-2011, 06:45 PM   #5 (permalink)
^^you can use dropbox. I would have downloaded but I am in office and dont use 64 bit os :/
Faun is online now   Reply With Quote
Old 25-04-2011, 07:13 PM   #6 (permalink)
Electronic.
Neuron's Avatar
I don't know if this can help but I found this on the brothersoft driver downlaod page.I guess it might contain both 32&64 bit drivers for the mobility series of gpus.
ATI Mobility Catalyst 9.11 Display Driver Display driver download
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 25-04-2011, 09:06 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Well, I DL'ed from your link, and then extracted the contents. Clicked on "CatalystMobility.exe", but it will not DL, cause it finds a mismatch to my GPUs...?
You want the extracted contents, I can upload them for you.
Try the Rage3d site. They have all drivers updated.
asingh is offline   Reply With Quote
Old 26-04-2011, 12:45 AM   #8 (permalink)
@Neuron: Hey many thanks for the link. But how should I ensure that the driver is meant for laptops?
@asingh: No I don want the extracted contents. I think that that driver can be downloaded only by those wio have that GPU. Bad luck. I will try your link too.
It would be better if ppl can give me links.
Really helpful ppl here.
Old 26-04-2011, 12:53 AM   #9 (permalink)
Electronic.
Neuron's Avatar
^^Mobility drivers are not for desktops.
Old 26-04-2011, 01:54 PM   #10 (permalink)
^^Oh well that true.
Well I found this driver on Lenovo's support site: http://www-307.ibm.com/pc/support/si...cid=MIGR-75692
Is this the correct driver for my system? Its for HD 545v. And they say that that driver will be supported by my lappy. Also I have heard that "545v" is the new name for 4500. Is that true? Windows 7 automatically installs HD 4500 driver for me. Are HD 4500 and HD 545v the same?
Old 26-04-2011, 07:41 PM   #11 (permalink)
Electronic.
Neuron's Avatar
^^Here you go
ATI Mobility Radeon HD 4500 Catalyst Software Suite v.11.3 download for Windows Vista 64-bit, Windows 7 64-bit
Old 27-04-2011, 09:40 AM   #12 (permalink)
^^This driver doesn't work at all. I downloaded the driver for Lenovo support site and that worked. I know its very stupid but I don't understand what card my system actually has. The Lenovo datasheet says that its "HD 5145", Lenovo's support site provides a driver for "HD 545v" (and that works very well), Windows installs "HD 4500" -- ?? Anybody, can you explain me?
Old 27-04-2011, 10:59 AM   #13 (permalink)
Super Moderator
asingh's Avatar
Download GPU-Z and run a screenshot here.
Old 27-04-2011, 05:13 PM   #14 (permalink)
See attachment:
Old 27-04-2011, 10:04 PM   #15 (permalink)
Super Moderator
asingh's Avatar
Well you have a "HD 545v". Are you able to install fine now.
Old 28-04-2011, 09:32 AM   #16 (permalink)
Yeah everything works like a charm. Problem solved.
Old 28-04-2011, 11:05 AM   #17 (permalink)
Fullbring
Zangetsu's Avatar
do post how it is solved.
It will help others users having similar problem
Old 29-04-2011, 12:07 PM   #18 (permalink)
Since I could not download the driver from AMD, I downloaded the latest from Lenovo's support site and that worked! It's that simple.
- by kool
- by kool
