Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 25-05-2010, 08:32 PM   #1 (permalink)
Question Rapidshare problem
From some days I am facing a unknown problem abt rapidshare... when ever i try to open www.rapidshare.com .. the page shows "Oops! This link appears broken.DNS error occurred. Server cannot be found."
I rapidshare is down or there is something which is blocking this site
how do u track a SIFIR :-)
chetan.g is offline
Old 25-05-2010, 11:39 PM   #2 (permalink)
geek........
Gauravs90's Avatar
Default Re: Rapidshare problem
change your DNS to openDNS
208.67.222.222
208.67.220.220
Gauravs90 is offline
Old 26-05-2010, 09:26 AM   #3 (permalink)
The Sexy Beast
better use google dns.works better than open dns
ratedrsuperstar is offline
Old 26-05-2010, 09:54 AM   #4 (permalink)
The Internationalist
Aberforth's Avatar
Open command prompt and run
ipconfig/flushdns
ipconfig/release
ipconfig/renew
..in that order. Also try using opendns as a user suggested above. It will probably work.
Aberforth is offline
Old 26-05-2010, 07:05 PM   #5 (permalink)
Exclamation Re: Rapidshare problem
208.67.222.222
208.67.220.220
not know how to do it ... and what is DNS
chetan.g is offline
Old 26-05-2010, 07:27 PM   #6 (permalink)
The Sexy Beast
^i think you have a reliance conn. they've either blocked rs for now or facing some prob.
all you have to do is change your dns ips in the same place where your ip address is entered.depending on your method of internet access,google to find where you'll find this.
normally you should get it in network connections->properties->ipv4
Old 26-05-2010, 11:22 PM   #7 (permalink)
geek........
Gauravs90's Avatar
open site www.opendns.com
There u will get guide to change your dns
Backup your dns in case you want to revert
Old 27-05-2010, 03:54 PM   #8 (permalink)
ohh it was DNS error ... I changed the DNS and it worked ..but i wanted to know how Suddenly it happened , initially my DNS was configured on "automatically obtain DNS" now, for everytime if i have to visit rapidshare.com i have to change the dns and then only i can open the rapidshare... actually what happened ??
chetan.g is offline
Old 27-05-2010, 09:13 PM   #9 (permalink)
The Sexy Beast
^kid,plz use the search portion at the top right of your browser
Dell Studio 15 Display Inverter and DVD Writer Problem windchimes Hardware Q&A 2 24-05-2010 12:48 AM
Ubuntu 10.04 "Low Graphics Mode" problem after update krishnandu.sarkar Open Source 6 23-05-2010 05:35 AM
problem with 16GB Cruzer micro rohit330 Hardware Q&A 3 16-05-2010 08:59 PM
Problem in Copy/cut paste bhavik Software Q&A 2 15-05-2010 10:52 AM
Problem viewing usage abhijangda Chit-Chat 4 04-04-2010 01:08 AM
- by bhaskar
- by Soumik
