Go Back   Digit Technology Discussion Forum > Bandwidth Wastage > Chit-Chat
Chit-Chat General discussions about anything that doesn't fit into the other sections to be had here
Old 07-05-2010, 12:56 PM   #1 (permalink)
Cool Freeup or clean RAM using notepad
RAM – Random Access Memory is one of the main component of computer that is responsible for the process of the operating system.Since all the Operating systems support Multiprocessing, hence require a good RAM speed. Since all the current running processes are stored onto the RAM, it slows the system speed. Sometimes the process which have executed but are not required by the OS are stored on the RAM. So, we can remove or freeup the RAM with unused junk data to Speedup the System or processing speed.
We can clean the RAM just by using a Notepad application. This donot require any advanced software. The process to do so is as follows.
Open Notepad
Type
FreeMem=Space(64000000)
save it as “CleanRAM.vbs” on desktop
Note: Type the name of file along with inverted commas
Run the file and your RAM may be free.
Of course you can edit the code in the file for a greater “cleaning-progress”.
For example:
FreeMem=Space(1280000000)
FreeMem=Space(2560000000)
FreeMem=Space(5120000000)
FreeMem=Space(10240000000)
Make Fun!!Have Enjoyment!!
Kool Centre
flamore_54 is offline
Can RAM of different frequency be used together? go4saket Hardware Q&A 3 13-03-2010 12:09 PM
Will there be any incompatbilty if i put a 1gb ram with my existing 2*256=512 ram???? tango_cash Hardware Q&A 7 03-07-2007 04:58 PM
THE QUEST 4 BEST RAM [flAsh] QnA (read only) 12 11-10-2004 06:04 PM
- by bhaskar
- by Soumik
