21-08-2009, 04:46 PM
mtnl broadband user check speed
There is partially increase in speed for 256Kbps Plan user (UL). check ur router for speed change. check the speed in ur router and post it in here
288Kbps download (Previously 263Kbps)
256Kbps Upload (previously 260Kbps)
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
23-08-2009, 09:47 AM
Re: mtnl broadband user check speed
^^ If you are in Mumbai then it is not supposed to be partial increase but a double of what you used to get. MTNL Mumbai has doubled the speed of all UL plans so if you are on 256kbps/999 UL plan you will now get 512 kbps..enjoy
23-08-2009, 09:25 PM
Nah, its the same
Download 256 kbps
Upload 253 kbps
24-08-2009, 09:06 AM
^^ You in Mumbai ??
Wait till this month end..it is being done in phases and timings may differ. I suggest you contact your local exchange or better call the customer care (1504 i think) and ask them why it has not be upgraded yet. Place a request for upgrade if they are taking it over the phone
25-08-2009, 10:52 AM
This partially increase in speed is for delhi user on other side in mumbai all unlimited plan get the doubled speed
25-08-2009, 11:25 AM
wtf it got reduced
253 253
25-08-2009, 12:52 PM
Core i7 (nehalem) Owner
use speedtest.net to test ur d/l and u/l speeds..  as for the upgrade plan (for Mumbai TRIBAND customers) yes its true...the plan got upgraded by MTNL, Mumbai on 15th Aug, 2009 wherein the speed of Unlimited plans has got Doubled (256 increased to 512, 512 older got increased to 1mbps and so on) but it will be implemented and reflected in ur plans from Sept 1st 09 only..  so plz hv patience..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
25-08-2009, 01:14 PM
26-08-2009, 10:49 AM
i hv been getting this speed for the past 1 month and im on 256kbps UL plan from triband..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
26-08-2009, 11:12 AM
^^ You in Mumbai right
Now i suppose MTNL has still not done the upgrade in your exchange/area because if that would be done then the speed would have got reduced to 512 kbps for you.
Mine happened that way only....was getting 2 Mbps since i hooked on to MTNL but the latest upgrade actually downgraded my connection
26-08-2009, 12:00 PM
yup buddy, me from Mumbai
yup, the upgrade (my from 256 to 512) has still not been done as it will be applicable only from 31st Aug.09 or 1st sep.09 so i cant say if my speeds will reduce or wat..lol...i hv been getting this speed for the entire Aug09 month..so i hope it will continue the same...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
26-08-2009, 01:20 PM
^^ The upgrade process started after 15 aug and will continue till aug end. I got those speeds for like 6 months before it went down to 512 kbps
So when in your exchange they do this speed upgrade chances are that you speed migth be reduced. If it does not happen then lucky you
26-08-2009, 01:45 PM
yaa i agree with ur point.. lets see wat happends, till now it has not happened (the speed reduction) ..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
30-08-2009, 10:28 PM
tHe nEw gEEk......ITian
Delhi : MTNL Triband 256kbps UL
I am getting D/L : 285kbps
U/L : 259 kbps
Getting this speed since 2 months,
But whats the big deal.......i m not experiencing any change in browsing/downloading.
31-08-2009, 12:14 AM
Most wanted
I am on night unlimited and i am getting this speed for past 1 year , so will there be any more increase in it , since i was thinking of shifting to cablenet .
31-08-2009, 12:36 AM
im also getting that same speed but jus since aug 09..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
31-08-2009, 02:50 PM
Most wanted
You are on which plan ?
31-08-2009, 03:08 PM
You are on Night Unlimited so you are bound to get that speed. But ashu on other hand is on full 24x7 Unlimited plan and he is ideally supposed to get 512kbps (as per the upgrade). But since past one month he is getting 2Mbps speeds (same as yours) and that is because of goofup by MTNL.
I too enjoyed 2 Mbps speeds for like 6 months when my plan was the 256kbps/999 UL plan but that is history now
31-08-2009, 11:50 PM
#19 (permalink)
@ rohan :
im on 256kbps unlimited plan but yes as rak007 said, i might be getting slow speed (if mtnl rectify the goof up)..lol..
@ rak :
i got my speed reduced..lol. see this
i dunno if its a temporary or a permanent rectification..  but the bottom line is tat my speed is reduced now..  but there is no change in plan details (the same old trib 256kbps ultd) on my account site...  strange..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
01-09-2009, 07:03 AM
#20 (permalink)
^^ see i told you buddy...this upgrade has been a downgrade to folks like us. First they get us addicted to 2 Mbps speeds and then give this measly 512kbps
Forget the plan name, they may or may not change it on website. Does not matter and i fear this speed reduction is infact permanent
But on the brighter side i see your upload speeds also in range of 512kbps. Now if this is constant (and not just a surge this time) then good for you.
01-09-2009, 11:51 AM
#21 (permalink)
ooh i see..  well yes its sad ending to a wonderful month of Aug 09 (where i was enjoying speeds of upto 2mbps
yup u are absolutely right buddy, i got addicted to the speed (2mbps)..lol.. now i think will hv to do away with this poor and irritating speed of 512kbps..
yup, its permanent and not just a surge in upload.. as i conducted a speed test again:
so now if my upload speeds are the same as my d/load speeds, shud i be keeping the upload speed in my tor*ent settings also the same.. ?? i mean upload speed=download speed.. ?? is it..?
btw, where are u located in Mumbai..?
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
01-09-2009, 09:23 PM
#22 (permalink)
I am not sure what needs to be done in torrent client. Yes i am from Mumbai but not currently in Mumbai.
01-09-2009, 11:45 PM
#23 (permalink)
k, thanx for the update..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
04-09-2009, 08:07 PM
#24 (permalink)
I took asianet 4mbps today. Changed from BSNL. I am getting 10+mbps. Here is it.
04-09-2009, 09:11 PM
#25 (permalink)
ooh my fcukin lord..lol... where are u located..??? not in mumbai i guess... lol..
nice speeds, thats every t**rent users wish to get those speeds..lol...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
05-09-2009, 04:53 PM
#26 (permalink)
I am from kerala. Asianet is available only in kerala. Be the fastest Indian on Net.
Posted again:
Actually it was 4mbps as per asianet, but i get more than 13 mbps. I was using bsnl 500 plan.
Plan Details
Plan 475
Rs 475/month
Free usage: 2600mb
Night unlimited: 2am-8am
Offer: Pay 24 months get 6 months free + 50% extra on monthly usage. (You get 2600+1300=3900mb/month)
Reason: Automerged Doublepost
06-09-2009, 12:41 PM
#27 (permalink)
a.k.a VipER
@mkerala
Nice mate. Is Asianet ISP the same as Asianet channel? (just curious to know)
Originally Posted by shayanthebest
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
06-09-2009, 05:21 PM
#28 (permalink)
Yes the same channel. Asianet has also cable service in Kerala, so they provide broadband too.
