29-06-2009, 12:15 PM
Manchester United
256kbps unlimited internet connection
Hi,
I want a 256kbps unlimited internet connection. Which one is the best, available in Kolkata? Please do not suggest me BSNL dataone. I want options other than BSNL dataone.
I was thinking of Airtel. According to the information available on www.airtelbroadband.in, the 256kbps unlimited connection is available for Rs.649 plus taxes and I also get a phone with Rs.100 local talktime per billing cycle. See the attached pdf file. And what is the fair usage policy? Will my data transfer limit be capped?
How is Tata Indicom photon or whatever they are advertising? I found it too expensive, as is Reliance Netconnect.
Please give your suggestions. Should I go for Airtel?
Thanks for your replies.
Edit: I am not being able to upload a file as attachment. Please excuse.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
29-06-2009, 12:21 PM
Bond, Desi Bond!
Re: 256kbps unlimited internet connection
Go for Airtel without any doubt. TATA Indicom sify reliance are pure crap!!
29-06-2009, 12:26 PM
Davislav Ivanuiz!!!
AirTel is your best bet. You won't be disappointed.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
29-06-2009, 12:29 PM
Manchester United
What is this fair usage policy? Will my usage be capped?
29-06-2009, 12:32 PM
Davislav Ivanuiz!!!
^ FUP has not been implemented yet, methinks; otherwise I would have had a crippled Internet connection by now
It basically means that once you exceed the download limit for the month, your connection speed is halved for the rest of the month.
Flickr!
29-06-2009, 12:37 PM
Bond, Desi Bond!
if you are going to have 256kbps, you will never be effected by Fair Use Policy as Airtel can't reduce speed below 256kbps (as per TRAI rule) for broadband connections.
Go for Airtel
29-06-2009, 12:39 PM
Davislav Ivanuiz!!!
^ Oh, I didn't realize that!
Flickr!
29-06-2009, 12:45 PM
AFK
No FUP for 256kbps as TRAI states that all connections above and equal to 256 kbps is broadband, anything below that means that they could revoke Airtel's license
29-06-2009, 12:56 PM
Bad to the bone
If you are not a download junkie, you can also consider 4GB @ 2 MBPS plan fro Airtel; its kicks some serious ass!!! I think its costs Rs. 1000/month.
Twitter: @amitabhishek
29-06-2009, 02:13 PM
Rockin g33k
I am into Tata and trust me, they dont deserve the negative publicity they get.Awesome speed, good prices and a happy customer.
My blog-www.rayarunava.com
29-06-2009, 02:15 PM
Bond, Desi Bond!
^^dude. I used TATA internet and it was pathetic. bad speeds, bad support. They ask me to renew my connection every month still when I had it disconnected in Jaunary!!!
29-06-2009, 02:22 PM
I was using Tata Indicom WiMax for about 5 months. In the first 3 months, it was very good, only 15-20 hours downtime max. However, during the last 2 months, connection disruptions became more and more frequent. During the first week of June, it didn't work from Thursday 10.30 pm. When I checked on Friday 9 pm, it was working. Then again, at 10.30 (same day) it stopped working. Me and my friend spend close to 150 minutes on phone with customer care. The connection became ok only by Sunday 6 pm. I expected a refund for this, but nothing.
Also, I got calls from CC asking me to upgrade to higher plan or face disruptions in connection twice during the last 2 months, since I have exceeded the fair usage limit of 45 GB. So, I have requested for termination of this connection.
Guess I will go with AirTel 256 kbps or BSNL EVDO.
29-06-2009, 02:28 PM
Bond, Desi Bond!
@unni, better go for Airtel.
29-06-2009, 02:36 PM
Sami Hyypiä, LFC legend
Though I hate to recommend and use Airtel services, however I think Airtel is the best choice here. Their service is good, consumer care less so.
I have this exact plan. Speeds are good, but the limited 4GB does hurt.
29-06-2009, 02:42 PM
Bad to the bone
Then you guys have not experienced Sify service; its a total $hit. I have suffered for 2 long years as I didn't had options. Average downtime of 5-6 days/month, useless dialer for Linux, frequent disconnections while in Linux, 256 felt like 128, clueless agents, restrictions of not using more thn two machine on one connection, I used to get renewal calls even after renewing  ... etc...etc...
In short they are ISP from hell...
29-06-2009, 02:44 PM
Then you guys have not experienced Sify service; its a total $hit. I have suffered for 2 long years as I didn't had options. Average downtime of 5-6 days/month, useless dialer for Linux, frequent disconnections while in Linux, 256 felt like 128, clueless agents, restrictions of not using more thn two machine on one connection, I used to get calls for renewal even after renewing  ... etc...etc...
Satyam...
29-06-2009, 02:46 PM
Bond, Desi Bond!
True. Local broadband providers used to be much better than Sify. I moved from Sity to TATA and finally to Airtel. Airtel is the only connection where there happened to be only 1 downtime in three months. It just never disconnects.
29-06-2009, 05:49 PM
mera kutch nahi ho sakta
I am paying 650 for 128 kbps in airtel (ahmedabad)
jin files ka koi server nahi hota unka bittorrent hota hai
29-06-2009, 06:02 PM
#19 (permalink)
Manchester United
29-06-2009, 06:36 PM
#20 (permalink)
EXIT: DATA Junkyard
^^True
29-06-2009, 07:44 PM
#21 (permalink)
sry, my bad I am paying 550 + 50 for landline + 50 tax
29-06-2009, 08:40 PM
#22 (permalink)
I think that Airtel do false billing and also have some hidden costs
With Regards
Jatin Jha
www.twitter.com/jatinjha
29-06-2009, 08:50 PM
#23 (permalink)
Bond, Desi Bond!
^^LOL.
ROFLMAO
#24 (permalink)
Bond, Desi Bond!
who doesn't have hidden costs. Am ready to pay 100 bucks extra if i can get uninterrupted internet 24x7
30-06-2009, 04:26 AM
#26 (permalink)
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
First learn the spelling of Broadband then say which is best...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
30-06-2009, 04:36 AM
#27 (permalink)
30-06-2009, 11:37 AM
#28 (permalink)
Manchester United
Originally Posted by Rural Terror
For the last 2 years I also had alliance 256kbps unlimited connection at Rs.499 per month. But it is down for the last 1 month, since cyclone Aila hit WB. They are making no efforts to rectify this. I call them every 2-3 days to remind and everytime I am told it will be done within the next day. This, combined with 5-7 days downtime every month has made me think of different internet connections. Otherwise, I was satisfied with Alliance for the 1st 1.5 years. Their pathetic attitude has made me take this decision. I too thought that was the best in Kolkata...
30-06-2009, 11:43 AM
#29 (permalink)
Evolving Rapidly...
@OP - just curious why ur avoiding BSNL....
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
30-06-2009, 12:50 PM
#30 (permalink)
Manchester United
If you are asking me, then let me tell you that I had major billing problems with BSNL dataone when I had the home 500 connection. After much trouble and harrassment and 2 1/2 years of fighting with BSNL officials (starting in July 2006 and ending in Feb 2009), I have managed to get that connection disconnected and the bills in the range of Rs.50k-60k waived off. My family and myself have vowed not to walk in the direction of any product of BSNL again...
