Hey RPM.....Did you buy the camera........you did not respond to my suggestion...hehe....its ok I guess you did not like it much.......Anyway but believe me.... that much I know Nikon makes far better professional camera than Canon and Sony...Any way have you checked out
Nikon D40x or D40. Very good mid entry level SLR performer.
Few of its key features....
10 megapixel DX format CCD (1.5x FOV crop)
Nikon Image processing engine
3D Color Matrix Metering II, 420 pixel sensor
New Multi-CAM530 three area AF sensor
ISO sensitivity range 100 - 1600 plus HI 1
3.0 fps continuous shooting, unlimited in JPEG
No status LCD, new LCD monitor based status / settings screens
Help suggestions on LCD monitor (eg. scene too dark, try using flash)
Large 2.5" 230,000 pixel LCD monitor
Bigger viewfinder view (x0.8 magnification, 95% coverage)
Short shutter lag and viewfinder blackout
Support for SDHC (SD cards over 2 GB in capacity)
In-camera retouching
D-Lighting (shadow / highlight enhancement)
Red-eye reduction
Trimming
Monochrome
Filter effects
Small picture
Image overlay
USB 2.0 with PTP and Mass Storage device support
Very compact, light body (smaller, lighter than D50)
Improved menu user interface (as D80 / D200)
New EN-EL9 Lithium-Ion battery (7.2V, 1000 mAh)
New 'Version II' AF-S DX 18-55 mm kit lens
Exclusive Review
