Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 24-06-2008, 08:16 PM   #1 (permalink)
irαhŬl
Default do these specs affect digicam quality???
hi frnds..
do the following specifications r the only tat determine the quality of a digicam photograph??
Sensor Size (inches): (ex 1/2.5" or 1/1.5") shud it be more or less??
Focal Length (35mm equivalent): (ex 38 - 114 mm)
Normal Focus Range: (ex 50 cm to Infinity
20.4 in to Infinity)
Macro Focus Range: (ex 1 cm - Infinity
0.4 in - Infinity)
Min Macro Area: (ex 31 x 23 mm
1.2 x 0.9 in)
Min Aperture: ex f/10.0
Max Aperture: ex f/3.5
Longest Shutter Time: (ex 1 or which is best
Shortest Shutter Time: ex 1/1000
r there any more specs needed to be seen to??..gonna buy a digicam tomoro..according to ur reply only am goin to select a piece..
rahulrajen is offline
Old 24-06-2008, 10:50 PM   #2 (permalink)
moshel's Avatar
Default Re: do these specs affect digicam quality???
dont knw many technicalities of digicams...but i believe that canon is the best in digicam business. I especially admire the A720IS.
moshel is offline
do these specs affect digicam quality??? rahulrajen Cameras and camcorders 2 25-06-2008 10:12 AM
do these specs affect digicam quality??? rahulrajen Mobiles and Tablets 2 24-06-2008 09:10 PM
Adding A Harddrive Will Affect The Performance ? jaisrigopi QnA (read only) 5 24-07-2007 12:41 PM
LCD Monitors don't affect Eyes ? Rishabh_sharma1990 TVs / Monitors 17 18-02-2007 04:45 PM
Games: How much they affect U TheMask Gamerz 50 07-09-2004 01:46 AM
