20-12-2006, 10:51 PM
Use handycam as a webcam
hi friends my question is can i able to use my handycam or sony digital syber shot camera as a web cam please tell me if anyone know about this issue if yes please detail how thanx in advance
21-12-2006, 07:48 AM
Re: Use handycam as a webcam
you can use. not aware of any issues.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
21-12-2006, 11:58 AM
The Researcher
Originally Posted by hailgautam
you can use.
But how?
21-12-2006, 11:58 PM
there are jack pins in either side or front side,, those are usb based and also firewire type.. in major handy cams the usb is been used to work the cam as webcam, and the firewire link connector to the handycam is for converting the video to harddisk for movie editings.
its pretty simple..
get the usb connector cable connect to computer oneside and other to handycam and enjoy..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
22-12-2006, 03:17 PM
The Researcher
its pretty simple..
Thank you. But can the same applicable to Digital Cameras?
22-12-2006, 03:58 PM
________
dunno which model u got, but in the one i have, 42e or sumthn, it has a couple of usb modes... one of them is a usb streaming mode, so before u hook up ur usb to the cam, go to the play/edit mode, and from the options, find the usb modes thing, switch it to usb streaming, then connect ur cam. it'l work as a webcam, and ur cam's microphone would act as a pc microphone.... dunno abt the firewire method, thats a lot faster from wht i've heard... good for editing/ripping off vids frm ur cam's tape...
about digital cams, well, some of them, in rare cases have a webcam/streaming mode, some dont, so thats model dependant...
phenom 9850be,M2N-E,2x2gb OCZ Platinum CL4 Edition,Leadtek 8800GTS320mb,Tagan 600w stonerock,200+320gb hdd,Optiarc20x DVDRW, SBLive! 5.1,PhilipsA2.610
"so long, and thanks for all the fish..."
25-12-2006, 05:35 AM
i have sony handycam HC46 model please give me details how can i able to use as a webcam
25-12-2006, 11:05 AM
________
okay, read what i've written pehle, u might just get it...
but i'l say it again...
put on ur cam, flick the switch on the side to enter the play/edit mode,
in the play/edit mode, find an option called USB Mode... or sumthn like that, enter that, theres gonna be 2-3 options, one would be a "pictbridge" option, the next would be "std. usb" and then a mode called the "usb streaming".
enable that mode, ie, the USB streaming mode.... now put ur cam on the docking station u use to connect ur cam to ur pc thru the usb cable....
now change the camera from the play/edit mode to the tape or memory card view.... it'l work as a webcam... i have a hc42e, but my sister's stolen it from me for a few days... but as far as i know, u have to change the camera from std. usb mode to usb streaming mode to work it as a webcam....
hope this helps...
cheers!
25-12-2006, 02:08 PM
mine is Sony cybershot DSC W-30. anybody who knows how to use this camera as a webcam?
28-12-2006, 09:28 PM
hey friends i m now using my handycam as webcam but i cant able to use voice chat at the same time plz tell me how i can i able to voice chat is it possible to send my voice through handycams mic or another mic is desired for that plz tell me in detail i will very thankful to you freinds
28-12-2006, 10:19 PM
________
try goin to the audio/video settings of ur chat program, change the microphone to usb audio... hope u installed the cam's drivers that came in its bundle...
28-12-2006, 10:52 PM
yes i have installed that driver of handycam i m trying thanx yaaar
29-12-2006, 04:02 PM
________
sall good...
