| Forum |
| Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there |
#1 (permalink) |
and i want to know that whether i can make the whole video in 1 segment????? then how???? |
#2 (permalink) |
Not gettin Ur Problem Correctly Mate.....Is ur Camera Dividing The video files into Various segments or is The Burning Software Dividing it???
Anyways If The Clips Are in .mpg Format then U Can use Vcd Cutter Or Many other Video Joining Softwares (Use Google) For Combining The Clips to One Whole Clip and Then Burning It on to The Disc.....But if Ur Cam's Dividing The Segments Then Dun Know a Way For That Buddy Plzz Provide Perfect Details :roll: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
