Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 05-06-2006, 08:03 AM   #1 (permalink)
Default best handycam under 20k
can u plaese suggest a good handy cam under 2ok
its very urgent
shivi4 is offline
Old 05-06-2006, 08:47 AM   #2 (permalink)
Default Re: best handycam under 20k
JVC D250 or go for the sony model visit sonyindia and get your all answers . I think u cant get panasonic,canon model in that range . good luck .
hellomotto is offline
Old 05-06-2006, 02:20 PM   #3 (permalink)
gxsaurav
Posts: n/a
no matter which cam u buy usually in that range Sony has only Hi8 format cam, don't go for these, go for DV cam
