Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 29-12-2005, 10:12 AM   #1 (permalink)
Default Help me......... to buy digital camera
hi ,
i joined today.
i want to buy digital camera having this feature
01. minimum 4MegaPixels
02. good indoor/ outdoor picture quality
03. shoul have good memory atleast 32mb
is sony-dsc-p60 ok?
can you guys suggest something?
cyrix is offline
Old 31-12-2005, 08:15 PM   #2 (permalink)
The pWnster
Vyasram's Avatar
nikon 4600 or 5600 will be great for u ... just make sure you get support in your area b4 buyin' couple it with a 512mb 0r 1gb sd card for storage
My 100th post
Sigs suck
Vyasram is offline
Old 01-01-2006, 07:13 PM   #3 (permalink)
i have Nikon Coolpix 7200 gr8 resolution, and feature too also support Video Recording
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
ravimevcha is offline
Old 01-01-2006, 07:47 PM   #4 (permalink)
Karthiksn
kato's Avatar
Wat is this Question doing in Reviews Section. Post in Q&A.
Post Reported
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 02-01-2006, 11:51 AM   #5 (permalink)
JGuru's Avatar
Buy anything 9000 + .Also check indoor & outdoor
Snaps. Also go for a minimum of 256 MB. You can store
a couple in 32MB memory if you shooting in 4 Mega Pixels!!
Digit mag has done a lot of reviews of Cameras. Check it out.
JGuru is offline
- by bhaskar
- by Soumik
