Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 20-10-2005, 09:57 PM   #1 (permalink)
Default HP Photosmart 318 Digital Camera doesn't work
Hi,
I'm Jeya Kumar.I have a HP Photosmart 318 Digital Camera. I have a Windows XP Pro.
Now the camera doesn't work. The problem is my Sandisk CompactFlash Memory Card doesn't reformat in my camera. When I try to turn it on, it says "CF card requires reformatting". Then it gives me the format memory screen, asking if I want to delete all images and files on the CF card. Whether I press yes or no doesn't make any difference, it just takes me back to the first message about the card needing reformatting. Is the card knackered or do I need to have a reader to be able to reformat it in this case?.
I tried to download the driver for above model from HP website, it looks like above 120 MB. And it contains many other model's drivers & imaging softwares. I want exact driver for my camera.
So what should I do to rework my camera?. Please help me.
Thanks in advance.
Kumar B.
pbjeykumar is offline
Old 19-11-2006, 06:14 AM   #2 (permalink)
Default Re: HP Photosmart 318 Digital Camera doesn't work
I am having the same exact problem. Did you ever find a solution?
Originally Posted by pbjeykumar
Hi,
Thanks in advance.
Kumar B.
Tman9135 is offline
