Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 15-09-2005, 11:13 AM   #1 (permalink)
Default Best buy digicam under 5.5k help guyz!
please guyz tell me the best digicam around a budget of 5.5k!
techmax is offline
Old 15-09-2005, 12:28 PM   #2 (permalink)
gxsaurav
Posts: n/a
if u can stretch your budget a little, u can but the Canon A400 for Rs 8.5k, with bill
3. 2 MP, which is enough for home use
it uses SD Card & a 512 MB card can take an approx of 400 pics at 1600X1200, Superfine & ISO 100 settings
Old 15-09-2005, 01:23 PM   #3 (permalink)
MVP in VC++
Yes... Canon A400 has very decent performance..atleast try that...
cvvikram is offline
- by bhaskar
