Results 1 to 6 of 6
Thread: DSLR for 38k!
30-09-2011, 05:47 PM #1Right Off the Assembly Line
- Join Date
- Feb 2011
- Posts
- 33
DSLR for 38k!
Hi guys, am a complete Newbie, absolutely no idea about the technicalities of a DSLR, can anyone suggest me the best i can get for 38k! Also would appreciate if you can explain why to go for that model?
Many thanks!
30-09-2011, 08:20 PM #2
Re: DSLR for 38k!
Nikon D5100 for arnd 34k wud be the best deal for you.. as u said you are nt aware of the features in DSLR.. you might find this difficult in starting.,.
I'd explain it to you, but your brain would explode... Trust me
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB+1.5TB Caviar Black, NZXT Phantom
30-09-2011, 08:44 PM #3
Re: DSLR for 38k!
For newbie i think nikon d3100 is enough.Correct me i am wrong.
My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
30-09-2011, 10:03 PM #4
Re: DSLR for 38k!
how I wish ur budget could be 45k and I would have suggested you D90+18-55 kit lens
anyways for 38k your choices are nikon D5100 and canon 550D
Even if people will say nikon D5100 have best sensor in the world still I would say canon 550D is much better for newbies...Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,Tamron 17-50mmf2.8 Lowepro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP, YN603-N3 flash trigger
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Samsung Omnia W with Sony MDR-ED12,Micromax Funbook & Samsung 550P-S05
01-10-2011, 05:23 PM #5
Re: DSLR for 38k!
Purely on a spec-to-spec basis, I think D5100 seems a better than D90 if VFM is considered.
Nikon D5100 vs D90http://TheSmallerBang.wordpress.com
eMachines E725 - Intel T4400 @ 2.2GHz, 5GB DDR3 RAM, 160GB Hitachi HDD
01-10-2011, 09:01 PM #6
Re: DSLR for 38k!
D90 is much much better in usability sense...keep tech aside
1. dual dials for easily changing settings
2. top screen to view current settings
3. Inbody focus motor which will enable you to have autofocus on lenses as old as 1970s and if u think who uses those old lenses then I will say I am using a macro lens maybe 20year old coz its cheap.
4. you can autofocus on 50mm 1.8
5. the body of D90 is much better made
6. I think it have bracketing, Depth of field button
7. more flash options (I am poor in this)
8. Amazing pentaprism viewfinder which really helps...my D3100 viewfinder is a crap and so will be of D5100
enough advantage over D5100 and 550D ...ultimately D90 is a midrange DSLR and these 2 r entry level onesPhotography Gears -
DSLR
By comkuter in forum Cameras and camcordersReplies: 3Last Post: 29-01-2012, 01:25 AM -
dslr help
By evilwit in forum Cameras and camcordersReplies: 4Last Post: 19-01-2012, 09:45 AM -
want a dslr
By evilwit in forum Cameras and camcordersReplies: 3Last Post: 15-01-2012, 12:04 AM -
DSLR - New DSLR buying advice/suggestion.
By binarycodes in forum Cameras and camcordersReplies: 9Last Post: 18-12-2011, 11:23 PM -
dslr for 35k max..
By bhushan2k in forum Cameras and camcordersReplies: 31Last Post: 10-10-2011, 07:20 PM
LinkBack URL
About LinkBacks
