Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Cameras and camcorders
Cameras and camcorders Buying advice and discussion spot for all shutterbugs out there
Old 21-08-2005, 12:15 PM   #1 (permalink)
Default DIGICAM
i wanna buy a digicam...within 15000. plz suggest some good ones.
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS...
BLITZ~KRIEG! is offline
Old 21-08-2005, 12:31 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try Nikon Coolpix Series, good ones...
Shud be in Hardware Reviews i guess...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2005, 08:28 PM   #3 (permalink)
tuxfan's Avatar
Nikon Coolpix!! I think this is my 100th post recommending it
tuxfan is offline
Old 22-08-2005, 04:07 PM   #4 (permalink)
MVP in VC++
Yup go for Nikon coolpix series they are best
cvvikram is offline
Old 22-08-2005, 07:57 PM   #5 (permalink)
Just Do It
Charley's Avatar
Old member, did u forget the SEARCH option
Here u are.
http://www.thinkdigit.com/forum/viewtopic.php?t=20320
http://www.thinkdigit.com/forum/viewtopic.php?t=26699
Charley is offline
- by bhaskar
