Page 1 of 2 1 2 LastLast
Results 1 to 30 of 35
  1. #1
    May 2011
    Kolkata
    Default Nikkon D5100 or Canon 550D
    Guys please suggest which one is better & why?
    Canon 550D or Nikkon D5100?
  2. #2
    Search for Adventure ITTechPerson's Avatar
    Apr 2007
    Kolkata, India
    Default Re: Nikon or Canon
    According to the Specification.. both r almost similar
    My choice is Nikkon....
    A Professional Camera..always Nikkon will b my 1st choice
    Take some suggestion on performance, before purchase
    Nobody is Perfect. I am "Nobody"
  3. #3
    New Gen Guru sujoyp's Avatar
    Mar 2008
    Orangecity
    Sensor wise D5100 better then 550D but feature and video is better in 550D...
    Grip is always better in Nikon
    Canons are mostly lighter in weight
    Photography Gears -
    Nikon D3100+18-55+55-200+50mm+55mmMicro,Tamron 17-50mmf2.8 Lowepro pro Runner 200 AW
    Yougnou YN-465 flash , Vanguard ESPOD 203AP, YN603-N3 flash trigger
    My flicker link -> http://www.flickr.com/photos/34748095@N07/
    Samsung Omnia W with Sony MDR-ED12,Micromax Funbook & Samsung 550P-S05
  4. #4
    Jun 2011
    I would say that Canon 550D is best because It is light wait camera . Moreover , Its picture quality is better than D550 . I would suggest Canon D550 .
  5. #5
    Broken In sumit05's Avatar
    May 2011
  6. #6
    Mar 2008
    Orangecity
    Nope that review is useless now coz nikons new sensor is superb which is in D3100, D5100 and D7000...and D5100 have same sensor a D7000 soo chances r that picture quality of D5100 may be better
    But overall I think canon 550D wins
    Photography Gears -
  7. #7
    In The Zone Sounava's Avatar
    Mar 2011
    Kolkata / Bangalore
    Quote Originally Posted by rock_dj View Post
    Go to a store, take both the cameras in hand, fiddle a little, try some shots, buy the one which feels more comfortable to you.
  8. #8
    Mar 2008
    Orangecity
    Default Re: Nikkon D5100 or Canon 550D
    @sonava....that way he will definitely get Nikon...actual in hand exp of nikon is much better..people love it
    Photography Gears -
  9. #9
    Mar 2011
    Kolkata / Bangalore
    Quote Originally Posted by sujoyp View Post
    If that is so then let him take it! If his hand is smaller he may like the Canon too. He may like the button placements in Canon better too. He may like the menu in Canon better too. Or maybe he may like the flip screen in Nikon too.
    I am telling all these coz both the cameras are equally good, no definite winner, so he must take the one which "feels" better to him after handling. This is your tool towards creating photographs, so you better buy which makes you feel better, than merely running towards specs. :-P You never know whether one will like Nikon or Canon better!
  10. #10
    Mar 2008
    Orangecity
    agreed
    Photography Gears -
  11. #11
    Apr 2007
    Kolkata, India
    Quote Originally Posted by Sounava View Post
    Like it....
    When both the models has a very little different in spech & performance, u should choose whichever is more comfortable to you.
  12. #12
    Mar 2008
    Orangecity
    Naah Specwise 550D beats D5100 practicaly.
    Like no issue with inbody motor or not....but almost all canon lens will work.
    Video recording is one of the best in 550D
    Photography Gears -
  13. #13
    Mar 2011
    Kolkata / Bangalore
    I disagree that specwise 550D beats D5100. If you say 5 points in favour of 550D, you will also be able to say 5 points in favour of D5100. Like I said, there is no definite winner.
    About the 2 so called "advantages" you mentioned in 550D:
    1. In body motor factor: Only advantage he will get is by using the 50mm f/1.8 lens of Canon. Otherwise, you will now practically get all lenses with built in motor variant.
    2. I will like to tell you that video recording in D5100 is also superb, if not better than 550D.
  14. #14
    Mar 2008
    Orangecity
    These so-called advantages were hyped everywhere soo I belived them...
    Photography Gears -
  15. #15
    Team Digit r4gs's Avatar
    Dec 2006
    I'm not sure I understand. My 50mm f/1.8 has a built in dc motor.
    @Rock_dj:-
    As Sounava said, go to the a store and check out the cameras yourself. Take some pics, compare the images at 100% magnification and see which one you prefer. Bear in mind that image quality will also depend on the LCDs on the cameras, so its best if you can view sample images elsewhere.
    Personally, if this is your first slr, I don't think it'll matter what you take.
    Reading made Don Quixote a gentleman, but believing what he read made him mad.
  16. #16
    Mar 2008
    Orangecity
    DC motor??? I heard this first time anyways we are talking about autofocus motor which comes in 13k model
    AFS 50mm 1.8
    Photography Gears -
  17. #17
    Dec 2006
    The auofocus motor is a DC motor.
    Which lens is that exactly? I only know of the canon EF 50mm f/1.8 i and ii models.
    AF-S is nikon isn't it? Souvana mentioned the canon lens.
  18. #18
    Mar 2011
    Kolkata / Bangalore
    ^ You are getting confused dude.
    What I meant is that if he buys 550D, he can use the 50mm f/1.8 and autofocus with it.
    If he buys the D5100, the corresponding 50mm f/1.8 will not autofocus on it.
  19. #19
    Mar 2008
    Orangecity
    eeh my office is killing my tech mind...soo sorry..
    yaah if u get any canon u can use cheap 50mm 1.8 with autofocus
    but if u get nikon cheap 50mm 1.8 wont autofocus on body like D3100 and D5100 the new AFS 50mm 1.8 will autofocus
    Photography Gears -
  20. #20
    Dec 2006
    Ah. That makes sense. Thank you for clearing it up.....
  21. #21
    May 2011
    I totally agree with you. Once, I was in the same situation D5100vs 550D. I went to store and tried out both for nearly 45mins. Now, I can say Nikon D5100 is right choice for me. Feature wise both are equally(Thin Hairline difference) good and so is the image quality.
    I really liked the comfort of holding the camera and that's the basic thing required for the DSLR. I will be getting the delivery in next 2 days .
    Buy from Authorized Nikon Dealer for details refer Nikon Support page. No Warranty for Non Authorized dealers.
    yaah if u get any canon u can use cheap 50mm 1.8 with auto focus
    but if u get nikon cheap 50mm 1.8 wont auto focus on body like D3100 and D5100 the new AFS 50mm 1.8 will auto focus
    Do u know Canon 50mm f1.8 uses micro motor to focus which is old technology and the auto focusing is noisy...try it before you buy. There is a new lens available from Canon 50mm and the price is slightly low 1K as compared to Nikon lens.
    Nikon AF 50mm f1.8D is for DSLR with in built motor like the D90. It works on D5100/D3100 but will need MF.
    Nikon AF-S 50mm f1.8G is new lens for D3100/D5100. It uses silent motor for Focusing(AF).
  22. #22
    Mar 2008
    Orangecity
    great info swiftlover
    Photography Gears -
  23. #23
    May 2011
    Thanks! The more you read the more you will get confused. Go to the nearest Canon/Nikon Dealership and try out the Camera's....Buy the one youa re comfortable...don't go on Features and all...all DSLR has pros & Cons
    Buy with 18-55mm kit lens first and once you are comfortable buy lens based on your requirement.
    Hope this helps you!
  24. #24
    May 2011
    Nikon has slashed prices of D3100, D90 and D7000 by 3k .
    For details refer to Nikon India website.
  25. #25
    Mar 2008
    Orangecity
    Quote Originally Posted by SwiftLover View Post
    Thanks what about lenses...I am thinking of selling off my 55-200 and getting a 55-300 instead
    Photography Gears -
  26. #26
    May 2011
    Just yesterday, I have received price list for Nikkor lens..
    Attached Images Attached Images
  27. #27
    Pharmaguru kjuvale's Avatar
    May 2004
    Pune
    Just checked the price list, found that there is no 50mm 1.8g (just wanted to check price in India against what I spent here ). Is this lens not yet launched in India?
    My Photography gadgets :
    Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
    Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
  28. #28
    Mar 2008
    Orangecity
    These r MRP ...I cant guss the prices by this
    Photography Gears -
  29. #29
    .NET Guru Champ's Avatar
    Jan 2006
    Delhi
    Hi Guys,
    For Past days I am also in same dilemma (D5100 VS 550D)
    I have made few observations, and would like to have Expert options on them.
    Both D5100 & 550D are Excellent VFM cameras, and you can not go wrong with either of them.
    Now once you buy Camera and play around with it and start getting bore.
    You need lenses to expand your capabilities. And from here real differences start to emerge.
    Now I am not considering third party lenses as not a single lens is available from
    Tamron/Sigma with VC/OS in less than 20K (data source : FlipKart).
    And believe me mortals like us, Do need such features with our shaky armature hands
    First lense any Beginner would buy : A decent Teleporto.
    Canon : EF-S 55-250mm f/4-5.6 IS @12K
    Nikon : AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR @18K
    Difference 6K
    As the time will progress you will realize importance of a good Prime
    Canon : EF 50mm f/1.8 II Lens @5.5K
    Nikon : Nikon AF-S NIKKOR 35mm F/1.8G @11.5 K
    Difference 6K
    Now every where I get to hear about Beginner Friendliness of Nikon but frankly speaking their entry level lens policy SUCK.
    Initially I was really Impressed by Bigger Sensor of Nikon but consider above fact and Excellent S/W Bundle of Cannon (Like fully controlling your Camera from PC).
    I am slowing tilting towards Cannon.
    Experts, Your option...
    Girls are like Roads, The more curves they have the more dangerous they are !!!
  30. #30
    May 2011
    Buying a DSLR is always a costly affair. If you need better quality u will need to spend more. Pls. go through the Links you will get answers to your Questions.
    Recommended Cameras
    Canon Lens
    Nikkor Lens
  1. Nikon D5100 vs Canon EOS 550D Which is Better????
    By syaoran7li in forum Cameras and camcorders
    Last Post: 27-06-2012, 01:34 PM
  2. Confused between Canon EOS 550D and Nikon D5100... Please help..!!
    By amneetahluwalia in forum Cameras and camcorders
    Last Post: 23-02-2012, 01:59 AM
  3. Canon 550D or Canon 1100D or any Nikon?
    By Kaustubh RocKer in forum Cameras and camcorders
    Last Post: 17-12-2011, 12:14 PM
  4. Replies: 19
    Last Post: 03-12-2011, 09:34 PM
  5. Best Macro lens for Canon 550D !!!
    By cyberdragon007 in forum Mobiles and Tablets
    Last Post: 05-09-2010, 11:44 AM
