Old 02-10-2008, 10:14 PM   #1 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Exclamation Wierdest problem on 6630
Hi guys , My friend has got a second hand 6630 two months back, it has a wierd problem i've ever saw, he cannot make call from contacts or Logs. . . Tried updating firmware and also reseting using *#7370# code, nothing worked, it will work for first 5 minutes or so after the phone is restarted, then again same problem, will flashing work out? I took to my local mobile vendor, he told he doesn't 've firmware for 6630, he just clicked 'FACTORY SETTINGS' connecting to that Tornado flasher.. But didn't work out that too.. Any other remedy frenz?
anish_sha is offline
Old 03-10-2008, 12:09 AM   #2 (permalink)
sam_1710's Avatar
Default Re: Wierdest problem on 6630
Thats a wierd problem...
Not sure if it'll work or not... jus try the 3 key format
sam_1710 is offline
Old 27-12-2008, 08:48 PM   #3 (permalink)
Hi Guys, i am facing the same problem. Please suggest a solution. Did you get a solution to your problem? I most wierdest thing is that my phone had same problem once earlier, but it got corrected by itself, and then suddenly again the same problem is occuring.
Thanks in advance.
gizmocrazy is offline
Old 27-12-2008, 08:52 PM   #4 (permalink)
AJJU
azzu's Avatar
Do the hard reset as told by sam it wud solve the problem
I love and Live to Design
azzu is offline
Old 28-12-2008, 03:58 PM   #5 (permalink)
it did not solve my prob, please tell me the way to correct it. Will updating the firmware help? It was locked on 3 network (UK) and I got it unlocked to use it in India. Will the firmaware upgradation lock it again?
Old 28-12-2008, 04:34 PM   #6 (permalink)
AJJU
azzu's Avatar
Mostly the Hard Reset Shud Work
yeah Try Updatin The Firmwae It shud Work Mostly
azzu is offline
The wierdest Gaming Gadget :D Quiz_Master Gamerz 11 13-11-2007 06:12 PM
6630 Memory Low problem official Buying Advice 13 24-10-2006 08:04 PM
Real Media Player problem in 6630 maharajadhiraj Buying Advice 5 11-07-2006 11:21 AM
Game Installation problem in 6630 maharajadhiraj Buying Advice 5 23-05-2006 12:56 PM
Problem in nokia 6630 while installing quick office maximus_3007 Buying Advice 8 23-10-2005 07:18 AM
- by bhaskar
- by Soumik
