Old 11-09-2008, 01:10 PM   #1 (permalink)
Bad to the bone
amitabhishek's Avatar
Default Suggest a Mobile under 6.4k
My company is going to pay 6.4K for an official handset. I am looking for a mobile which can play some music.
I would prefer quality of sound over storage and other frills. My other/personal phone e61i is a lousy when it comes playing to music.
Twitter: @amitabhishek
amitabhishek is offline
Old 11-09-2008, 02:46 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Suggest a Mobile under 6.4k
If u can extend ur budget then Nokia 6233 is good for 7k (loud music & gud sound quality)
Blogging at:
Technostarry
saqib_khan is offline
Old 11-09-2008, 03:44 PM   #3 (permalink)
Cool G5's Avatar
Get Nokia 3110c.
Cool G5 is offline
Old 11-09-2008, 04:46 PM   #4 (permalink)
Tech.Masti's Avatar
Nokia 3500, 3110c or se K550i, its would be better if you can increase your budget to 7k for 6233
Tech.Masti is offline
Old 11-09-2008, 08:43 PM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
3110c + 2.5mm to 3.5mm jack + ep630
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 11-09-2008, 09:10 PM   #6 (permalink)
hell boy
K550i or the karets combination
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Suggest a low end mobile.. sbhas2k Buying Advice 2 22-10-2007 12:15 PM
Suggest a mobile under 5k sbhas2k Buying Advice 8 28-11-2006 11:16 PM
Suggest a mobile cooldip10 Buying Advice 5 04-09-2006 04:57 PM
Suggest me a mobile around 10-12k! ~Romil Buying Advice 13 26-11-2005 02:14 PM
suggest me a mobile. rajas700 Buying Advice 1 24-09-2005 02:15 PM
- by bhaskar
