| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
Im in search of a phone with the following requirments -good music through the headset -good keypad and good quality. By quality I mean the paint should not peel off, the keypad and navigation should work even after rough use. Im planning to keep the phone for a few years atleast. -decent enough camera with flash/autofocus -has to have GPRS, EDGE and 3G and a good browser I currently have in mind C702 and w760? w760 seems good but im skeptic about the slider and keypad. Will it be durable? I dont care about GPS so I can also consider w890i. Also will there be a considerable quality difference between walkmans and c702 through the headphones? |
#2 (permalink) |
AJJU
c702 is a good buy but i sugg u extend the budget and consider n82 and c902
and yea there will be a huge diff between the regular and w series head fones but u can easily get a hpm-70 or ep-630.. at 500-600/-
I love and Live to Design |
#4 (permalink) |
Be CoOl rAp RuLeZ !!!
ep-630 sounds much better but for 15k try getting the N81 or C702
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 |
#6 (permalink) |
W760 lacks AutoFocus and Flash....Its camera isn't great.
C702 all the way. it has got terrific build quality seriously. It has also been even awarded for that. It is splash resistant. You can easily use it in rain...The water will not enter inside... It has the best 3.2mp day camera......This time Krates you'll not have any objections as it is definitely better than K790i/K810i during day..... Plus, it also has GPS.... C702 + HPM-70 will be the complete combination of Camera and Music and you should definitely go for it...... It also got MegaBass.... Build quality of N81.....It sucks......
Won't be replying to PMs for a while. Stay in touch with e-mail. Read before asking / messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. Last edited by ico; 24-08-2008 at 08:04 PM. Reason: Automerged Doublepost |
#8 (permalink) |
AJJU
correction c902 to c702 (?) go for the c702 its good mobile and on ur quiry about earfones ep-630 r faar better than the walkman earfones so dont worry
#9 (permalink) | |
But how'll EP-630 work with C702??....Aren't they 3.5mm...But in the end, who'll like to carry the adapter....And you'll also loose the MIC facility... C702 + HPM-70 is pretty good. If you want more then get more superior HPMs. @prasanthsd If you'll get the W890i, then the camera will not be that good. It lacks AutoFocus & Flash.
Won't be replying to PMs for a while. Stay in touch with e-mail. Read before asking / messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. Last edited by ico; 24-08-2008 at 08:03 PM. Reason: Automerged Doublepost |
#10 (permalink) |
respect mah authoritah!!
you wont lose the mic.as there is a mic in hpm 70. better to buy c702 and hpm 70 you will have great music and great camera.
HP DV6 1319tx N82 8GB(black) Sony Cybershot DSC T500 Jabra BT3030 PSP phat(5.00 m33-6) |
#12 (permalink) |
TECHNOHOLIC..............
I think you should go for K850i, its available in SONY WORLD for 15.8k. 5MP Camera & gud music quality. Or C702 but it has 3.2 MP camera.
"You go to your TV set when you want to turn your brain off. You go to your computer when you want to turn your brain on." - STEVE JOBS |
#14 (permalink) | |
Techtree Reviewer
I'd like to suggest you Nokia E51. But it costs 11k which is a bit beyond your budget. But it is worth it if you could stretch a bit.
Prasad Naik Technology Reviewer for TechTree.com |
#15 (permalink) |
dude this isnt called hijacking if u been to a lot of forums , moderators actually prefer to ask in current threads rather then spaming ok? it helps keeping the forum clean .. ..and fr budget i think i can strech to 15k
#16 (permalink) |
^^^ what are your preferences dude ?
dumb phone or a smart phone ? music camera ? what ?
#18 (permalink) |
ummw waht options do i have .,..i want a symbian phone or windows phone .....
i want decent music quality with 3mp camera atleast .. so which one should i go for? i was going for htc it costs 10k and n73 13k approx any other ideas? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Want a budget phone | mad1231moody | Mobiles and Tablets | 14 | 01-08-2008 12:23 AM |
| Budget phone upto 12.5k | Tech$oft | Mobiles and Tablets | 20 | 29-07-2008 10:19 PM |
| New Phone Budget 20k-30k | sinoop_joy | Buying Advice | 40 | 19-01-2008 12:20 PM |
| I need a phone. The budget is ten thousand. | aryayush | Mobiles and Tablets | 39 | 10-07-2007 12:14 PM |
| need a phone, max budget : 8k | maharajadhiraj | Mobiles and Tablets | 11 | 21-06-2006 06:05 AM |
