| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
I used PC suite. Message: installation not supported. What could be the problem?
Modern technology Owes ecology An apology. ~Alan M. Eddison |
#2 (permalink) |
Be CoOl rAp RuLeZ !!!
Add me to yahoo or msn i will tell you bunch of applications !@!
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 |
#3 (permalink) |
Techtree Reviewer
N70 and N73 use different versions of operating systems. Hence their applications are different and you cannot install the apps meant for one phone on the other. There is a different set of apps available for N73. Try and get those.
Prasad Naik Technology Reviewer for TechTree.com |
#4 (permalink) |
respect mah authoritah!!
any applications for n82. And do i have to buy ngage games pm me if you have an alternate method.
HP DV6 1319tx N82 8GB(black) Sony Cybershot DSC T500 Jabra BT3030 PSP phat(5.00 m33-6) |
#8 (permalink) |
hey add me to yahoo or msn messenger and then we will have a chat there
#10 (permalink) |
pm me your id i don't see you in my messenger list
#11 (permalink) |
As said above, n73 is s60v3 device while n70 is s60v2(not exactly 2).
So the softs of n70 won't work on n73. @rahul - Remove that link from your post.
ShutterTux - Photography, Linux & Life! : http://shuttertux.wordpress.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 2600c Apps and Games | BSOD | Mobiles and Tablets | 1 | 21-07-2008 11:57 AM |
| Any good apps for nokia... | Sparsh007 | Mobiles and Tablets | 2 | 19-11-2006 07:05 PM |
| Help a PHP newbie | tuxfan | QnA (read only) | 3 | 22-07-2005 07:01 PM |
| help me fix this bug. a newbie! :( | legolas | QnA (read only) | 16 | 10-04-2005 10:52 PM |
