Old 24-08-2008, 09:19 AM   #1 (permalink)
chavo's Avatar
Default Need ur review about my new mibile phone
hey guysss....
i recentlly got my new mobile phone Samsung beat i450.....
i need some reviews from all u guys.....
Any new features...applications.......
I have seen one option which is 'GPS DATA'.....
can any one tell me what it is?????
All u guys are always been helpfull to me. Thax for that.
Waiting for ur reviews....
& please guys help me to get the "restriction code" for my nokia 5310.
i got it from U.K.
chavo is offline
Old 24-08-2008, 10:35 AM   #2 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Default Re: Need ur review about my new mibile phone
it is a symbian phone start installing appz !@!
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 24-08-2008, 12:40 PM   #3 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
Start installing apps right away. Though app support on samsung is not as good as N81 , but still there are many apps available.
I wonder why did you choose this phone over other phone in this range ?
Tamoghno is offline
Old 24-08-2008, 12:53 PM   #4 (permalink)
Rockin g33k
dreamcatcher's Avatar
You bought the phone.So you should be the one giving the review.Isnt it??
My blog-www.rayarunava.com
dreamcatcher is offline
Old 24-08-2008, 02:01 PM   #5 (permalink)
respect mah authoritah!!
girish.g's Avatar
i would prefer i450 over n81. i450 has its own advantages over n81
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
girish.g is offline
Old 24-08-2008, 03:53 PM   #6 (permalink)
Devil_S
sautrik's Avatar
Question Re: Need ur review about my new mibile phone
What advantages exactly are you taking about? Can you please explain.
sautrik is offline
Old 24-08-2008, 04:38 PM   #7 (permalink)
girish.g's Avatar
for a music phone it has a pretty good and simple interface. The clickwheel is nice and useful. I have used both phones my friends have it.
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
girish.g is offline
Old 24-08-2008, 05:29 PM   #8 (permalink)
AJJU
azzu's Avatar
i450 looks gud but it has not so good interface ...
I love and Live to Design
azzu is online now
Old 24-08-2008, 05:57 PM   #9 (permalink)
God of Mistakes...
Garbage's Avatar
Send me your phone for a week so that I can review it !
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 24-08-2008, 06:02 PM   #10 (permalink)
AJJU
azzu's Avatar
^thats a good idea
azzu is online now
Old 24-08-2008, 08:03 PM   #11 (permalink)
@ girish
I450 is not bad phone overall . But N81 is definitly better buy. Because
N81 have brighter & better screen. Much much better . This reason alone enough for me.
Have better support for Application including nokia beta labs application which i450 wont run at all .
Can run ngage games . One of the few phone is market to support landscape ngage games.
Have better music player interface. Beat's default music player is old and music player that starts after sliding upwards is not very user friendly( though visually attractive )
The wheel thingy in beat is worst . The rubber keys are hard to press and practically useless. Whereas N81's naviwheel is much much more user friendly , not sticky as rubber and most importantly can be used in many more application .
N81's music keys are available from anywhere . No matter what you're doing , what application you're working on you can control music player without leaving the app. This makes is a perfect ipod replacement.
You cant use your headphone to receive call . You have to use the prophetary port's handsfree. In n81 you can receive and hear call using any earphone in 3.5 mm jack.
Unless you slide down the beat , the speaker is blocked and produced muffled sound . I dont like the idea of putting speaker behind slider.
N81 have wifi and voip capable.
N81 recently updated with new firmware which gives it fp2 features like transition . And the browser now supports flash video.
I've checked n81 , i450 in store using a bose headphone and with same songs. Honestly i couldn't find much difference . In flat eq setting , i450 sounds better with better bass but just tweaking the eq on n81 makes them equally good. I450 dont have custom eq which is bit letdown , and the 3d effects makes the sound so artificial.
And n81 comes with 2 gig card and better accessories at 14100 , beat probably cost around 13200 and comes with 1gig. Thats why i think its better to get n81 instead of i450.
Tamoghno is offline
Old 25-08-2008, 04:20 PM   #12 (permalink)
girish.g's Avatar
ok agreed. i have used i450 for a longer time than n81 maybe thats why. i450 has pretty decent output through headphones but through speakers my n82 is better. btw any idea on how to get ngage games for free
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
girish.g is offline
Old 25-08-2008, 04:29 PM   #13 (permalink)
Fullbring
Zangetsu's Avatar
speakers r little lower than N73 i guess
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 25-08-2008, 08:54 PM   #14 (permalink)
Speakers aren't strongest on n81 . But i guess its limited by firmware because the its really loud when rings .
Regarding ngage , i dont know if its allowed to talk about cracks in digit forum . But dotsis.com is a nice place to start .
But i'm not sure if i450 can run ngage games. Because its supposed to be a nokia only feature . Not sure though.
Tamoghno is offline
Old 26-08-2008, 01:28 PM   #15 (permalink)
The Techno Perv
i too got i450.. mostly coz i am a music fanboy and PERSONALLY i450 sounded better to MY EARS..
also I found the keypad better than n81.. n81 has wifi which i dont need.. ngage games?? well i own a monster PC which can play any game in the market currently so i dont really need any more distractions ..
better display in n81 which is probably was the biggest draw back in i450 i feel.. i m using it as a transition phone though.. wil change to sony erikson w902i wen it comes out..
P.S: look at the words in capital before u ppl start arguing with me..
dtox is offline
Old 26-08-2008, 01:41 PM   #16 (permalink)
krates's Avatar
waiting for a review with screenshots
krates is offline
Spice D80 Dual GSM Phone Review kumarmohit Mobiles and Tablets 7 24-11-2007 02:42 PM
REVIEW : Sony Ericsson K750i 2 Megapixel Phone khandu Mobiles and Tablets 25 22-10-2007 04:29 PM
REVIEW : Nokia 6255 CDMA Phone.. it simply ROCKS!!! for RIM khandu Mobiles and Tablets 10 19-11-2006 07:05 PM
Sony Ericsson W550i Walkman Phone Review devilhead_satish Mobiles and Tablets 9 14-04-2006 12:03 PM
Help needed for buying a mibile phone lovelygrll Buying Advice 9 06-11-2005 11:54 PM
