Old 23-08-2008, 03:12 AM   #1 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Default Need Mobile in the range of 15-20K
Hello guys, My brother need a mobile within the range of 15-20K ( max 22 with a bluetooth handsfree). I am interested in WM 6.1 Pro mobiles, but other good phones in this range will do. It should be very friendly for business purpose. He doesnt listen any songs, but he occasionally takes snaps and records videos. He currently has Motorola L9.
The phone should have the following.
1. Excellent voice clarity (Very Important)
2. WIFI (Very Important)
3. Large touch screen
4. Should be slim ( N-Series phones are bulky )
4. GPS
5. Should be able to read Word/Excel files in case of non WM phones.
6. Huge phone book memory.
Also recommend bluetooth hands free within the budget.
And last request.. NO SAMSUNG PHONES.. He hates them.
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is online now
Old 23-08-2008, 05:30 AM   #2 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
Default Re: Need Mobile in the range of 15-20K
E71 . Dont have touchscreen though.
Faster than every windows mobile out there. And one of the slimest business phone.
If winmo is must then htc touch
Tamoghno is offline
Old 23-08-2008, 07:41 AM   #3 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
look no further go and buy E71
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 23-08-2008, 08:41 AM   #4 (permalink)
Rockin g33k
dreamcatcher's Avatar
G900. Has everything you crave for.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 23-08-2008, 10:10 AM   #5 (permalink)
AJJU
azzu's Avatar
yes G900 is good fone but has no gps (iam i rite ? ) and not a big tuch screen
and also e71 is excellent fone but no touch screen ,
I love and Live to Design
azzu is offline
Old 23-08-2008, 10:17 AM   #6 (permalink)
shashank4u's Avatar
e71 and P1i are your best bet
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 23-08-2008, 10:20 AM   #7 (permalink)
Rockin g33k
Well G900 is extremely slim and the touchscreen is not bad.Check it out somewhere.It does not have a GPS chip but it tracks your presence using your cell EMEI, which it transmits to the sattelite and then receives your position within a range of 100 metres.
Old 23-08-2008, 10:25 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
1) Wait for Xperia
or
I would recommend these:
HTC P3300. Microsoft Windows Mobile 5.0 PocketPC phone with touchscreen, Wi-Fi and EDGE support, an integrated GPS receiver, microSD, 2mp cam. should cost around 17k-18k
Sony Ericsson P1i. 16k-17k (no push email functionality)
Sony Ericsson G900 20k superb 12hr talktime
When it comes to corporate use, nothing beats Windows mobile. loads of 3rd party apps.
desiibond is offline
Old 23-08-2008, 10:34 AM   #9 (permalink)
Google Bot
Pathik's Avatar
E71
Pathik is offline
Old 23-08-2008, 10:37 AM   #10 (permalink)
Rockin g33k
Btw, if he is into snapping pics then bunk the E71 and get him the G900/n82. Coz the E71 takes pathetic pics.For everything else.E71.
Old 23-08-2008, 11:08 AM   #11 (permalink)
Techtree Reviewer
krazzy's Avatar
If he can live without GPS then G900.
If he can live without touchscreen then E71 or N82.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 23-08-2008, 11:13 AM   #12 (permalink)
Techans
nikhilpai's Avatar
Or N95 classic
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
nikhilpai is offline
Old 23-08-2008, 02:11 PM   #13 (permalink)
At Hell's Disq
hellgate's Avatar
its not recommended to go 4 the N95 Classic when u can get a much better device with more advanced capabilites in that price.
hellgate is offline
Old 23-08-2008, 02:30 PM   #14 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Thanks a lot for the reply guys.
pi1 drops out cause it has only 802.11b I operate my wifi with 802.11g.
G900 & E71 has excellent features, With take a look in a Mobile Store.
@desiibond: When is xperia releasing ? I have to get the mobile before 20th next month. P3300 is a WM 5.0 Mobile.. I need WM 6.1 Pro.
Please give me some more options to choose from.
EDIT: I can streatch the buying date till 19th or 20th of september.. is there any upcomming new models within this date?
Old 23-08-2008, 02:38 PM   #15 (permalink)
Rockin g33k
XPERIA will be out of your budget anyway. How about the Touch Diamond??A bit on the higher side tho.
Old 23-08-2008, 02:49 PM   #16 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Diamond is little slow
get E71
X1 would cost above 30k
Apple Macbook Pro 17
nish_higher is offline
Old 23-08-2008, 03:06 PM   #17 (permalink)
>:)I-):(|)8-X
Charan's Avatar
hmmm.. I can add a additional 5 K to the budget only if the mobile is really worth for the money.... if the touch diamond is slow .. then its out of the question.
xperia is out from my list. will not be pocket friendly..
Also my brother doesnt give respect to his mobile phone.. it has to be sturdy also
Old 23-08-2008, 05:27 PM   #18 (permalink)
Rockin g33k
Touch diamond is slow?? :O
Anways.Wont comment as I havent used it.If you value a touchscreen then G900 it is.
Old 23-08-2008, 05:45 PM   #19 (permalink)
Alter Bridge=GOD
^ i have used it for 2 days..it has 192 mb ram but only around 40% is available and that too when that 3D func is off.imo this phone is slower than my P527 when it comes to multitasking..
Old 23-08-2008, 05:47 PM   #20 (permalink)
Seems like you're care for speed. E71 is fastest corporate oriented smartphone in that range.
And yes , touch diamond , though faster than most winmo ,is still slow . Also there are serious issue with battery life .
Tamoghno is offline
Old 23-08-2008, 05:49 PM   #21 (permalink)
Alter Bridge=GOD
yup E71 is fast and good
also touch diamond is locked with Airtel
Old 23-08-2008, 07:06 PM   #22 (permalink)
Techans
nikhilpai's Avatar
If someone doesn't need the Xenon flash buts need a larger screen with a better keypad, N95 classic can still be considered. Plus now its price has dropped by 2k
Old 26-08-2008, 11:46 PM   #23 (permalink)
>:)I-):(|)8-X
Charan's Avatar
ok E71 is on the cards .. now new requirements .. should have touch screen..
Im now ok to go with samsung phones too..
Old 26-08-2008, 11:46 PM   #24 (permalink)
Wire muncher!
infra_red_dude's Avatar
G900, P1i, HTC 3300 are what I recommend. With HTC you get your WinMo 6.1 pro too.
infra_red_dude is offline
Old 27-08-2008, 12:38 AM   #25 (permalink)
shashank4u's Avatar
802.11b is enough for mobile, also UIQ 4.0 could release any time soon and P1i will get a free update.
still i find E71 the best but it doesn't have touch support.
Old 27-08-2008, 12:47 AM   #26 (permalink)
>:)I-):(|)8-X
Charan's Avatar
^^ you sure P1i will get UIQ 4.0? can I get the link from where you read it?
Old 05-09-2008, 06:56 PM   #27 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Update. I have decided to take a look at Asus P750 I had used this phone before for an hr or so .. and I liked it. this phone is under my budget.
Old 05-09-2008, 07:12 PM   #28 (permalink)
"The Gentleman"
vish786's Avatar
@charan, thats a nice one with all goodies.
from are you getting that cell
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 06-09-2008, 12:55 PM   #29 (permalink)
>:)I-):(|)8-X
Charan's Avatar
Im going straight to Main Asus dealer in Bangalore . he quoted Rs. 20,250 +/- For P750. In Sangeetha its Rs.21799/-
Old 08-09-2008, 02:03 AM   #30 (permalink)
>:)I-):(|)8-X
Charan's Avatar
I have bought the ASUS P750 Win Mo 6.1 Phone for Rs.20250 /- Including all taxes. I bought it from primary ASUS dealer in bangalore. Unfortunately I have not opened the box cause its a birthday gift for my brother so cant give the review right now.(or do R&D myself ) .
The dealer gave me a standby phone for sometime to explore before I bought it. Features are really good and I got more than I asked for.
Wifi: 802.11 b/g
3G: HSDPA, 3.6 Mbps ( Future proof )
TFT touchscreen, 65K colors ( No problem with 65K )
Business Card Recognition
Pocket Office - Word, Excel, PowerPoint, PDF viewer
GPS receiver
Location Courier - GPS Related , this sends GPS locations as a SMS to any predefined number from time to time and that can be used to track the exact position of the mobile in another mobile. Google maps can use this data and plot point it in maps , he demonstrated this by tracking his friends phone .. really cool feature to have. This was the one feature which impressed me a lot
Travel log(or something with that name) - This application can store the location's of you travel path as and when you move from one place to another and then plot it back on the map
Free Maps for abt 35+ cities in India.
Free 1GB MicroDS Card ( The maps are installed in it)
The phone which I was checking out even had a bloody remote desktop
I dont know if it was pre-installed or not.
My dealer said that the pack includes a phone holder for the car and also a free Car charger , only thing missing is a extra battery .
Please bear with me for the full review of the phone, it aint gonna happen atleast till 2 weeks. Yes I bought it 2 weeks in advance
EDIT: Please recomend me a BlueTooth headset . It should be very slim and less than 2K.
my dealer said not to use a bluetooth headset cause he was getting pain in his ears after long use . And any one throw some light on this?
Mobile in the range of 5-7k Dink2cool Mobiles and Tablets 15 18-04-2009 12:58 PM
Best mobile in the range of 10k to 15K sagarkumar Buying Advice 38 12-02-2009 05:04 PM
friend need laptop in range 30 k n' a mobile hskpunjabi Laptops and Netbooks 2 01-08-2008 10:36 PM
New Mobile In Range Of Rs6000-7000 caje143 Buying Advice 6 04-03-2007 02:40 PM
Best Mobile within 15k-20k Range thecyclone2k Buying Advice 19 22-02-2006 03:47 PM
