Old 15-04-2008, 12:33 PM   #1 (permalink)
pushkar's Avatar
Default Problem with 5700
Problem 1
Since I have bought my Nokia 5700, I cannot play videos properly on the built-in RealPlayer in the phone. The videos play sluggishly with pauses of 1-2 seconds every 10 seconds. I tried CorePlayer and the videos play perfectly all right in that. Does any other 5700 user have the same problem? I use Nokia Video Manager to convert the videos to mp4. I have used other converters also, but the videos don't play well in real player in my phone, but while in coreplayer, they play well.
I would have stuck to coreplayer but the problem is that I cannot fast forward or reverse in coreplayer. whenever i try to forward the video, it starts from the beginning. i have tried coreplayer v1.2.0 and 1.1.2. Can you people suggest any solution?
Problem 2
Since I have got my phone's firmware upgraded to v4.21, the City Bloxx game gives sluggish performance. I cannot play it properly because of the slow performance. I have tried reinstalling the game, but it does not help. Is anyone else having problem with city bloxx in v4.21?
pushkar is offline
Old 15-04-2008, 12:38 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Problem with 5700
PROBLEM 1
I too face the same problem.I think some firmware upgrade will help.Also they do not pause in normal i.e vertical mode.The problem only comes in horizontal mode.
PROBLEM 2
No, I haven't yet upgraded to 4.21, so no idea about it.
But have heard about the issue on net.
Cool G5 is offline
New 5700 Pathik Buying Advice 10 16-01-2008 11:54 AM
N91 4gb/n72/5700 Kaushik Mobiles and Tablets 32 10-08-2007 06:30 PM
A problem with the Nokia 5700 abhishekkulkarni Buying Advice 3 11-07-2007 10:26 AM
XFX 5700 le - Problem help? ganesh_2218 Hardware Q&A 1 09-11-2005 12:54 AM
Wanna know how to convert a 5700 LE into 5700 ultra ? regenade QnA (read only) 6 16-11-2004 11:36 AM
