Old 06-03-2008, 08:07 PM   #1 (permalink)
tech_cheetah's Avatar
Default An interesting problem
When i connect motorola s9 over bluetooth to my w580, it works fine. I tried listening to radio - connected the handsfree cord
,which acts as radio antenna and simultaneously connected s9 also. But the sound got pumped into the cord instead of s9
Then i turned off radio and turned on walkman player. To my surprise, the music this time came into s9.
I tried figuring out some option to get radio sound through bluetooth but didnt get any.
Does anybody know its feasibility ?
Be honest . By that way u can be sure that the world is short of atleast one rascal.
tech_cheetah is offline
Old 06-03-2008, 09:53 PM   #2 (permalink)
Rockin g33k
dreamcatcher's Avatar
Default Re: An interesting problem
yea u can..theres a way..i think u hae to bluff the phone into thinking tht theres an antenna attached....like putting in a pin and then streaming..
btw..hows ur s9 xperoience??..m planning on buying one for my k850
My blog-www.rayarunava.com
dreamcatcher is offline
Old 06-03-2008, 10:30 PM   #3 (permalink)
Google Bot
Pathik's Avatar
It is like the wired headfone has a greater priority than the wireless one. So if u connect both, the audio ll play through the wired one.. Try using a mock pin or something.
Pathik is offline
Old 07-03-2008, 12:32 PM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
Please don't. It lacks bass and only the left speaker works for calls. Just get SE HBH DS970. It has the best sound quality and is cheaper than S9.
krazzy is offline
Old 07-03-2008, 12:34 PM   #5 (permalink)
@amd64_man2005
How will the phone play radio without connecting wired handsfree and just with a pin ?? I dont see any place where i can insert a pin in the phone .. the radio gets played only once wired handsfree is inserted
@Pathik
When both (wired and bluetooth) handsfree are connected then :
1. Radio plays thru wired one
2. Music plays over bluetooth
Old 07-03-2008, 01:35 PM   #6 (permalink)
Rockin g33k
@krazy..yea but i wanted a total wirefree setup which the ds970 lacks in...
@cheetah
u have to place the pin in the fast port itself..
Old 07-03-2008, 01:40 PM   #7 (permalink)
respect mah authoritah!!
girish.g's Avatar
@amd64_man2005
what pin??
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
girish.g is offline
KEO - Damn Interesting expertno.1 Chit-Chat 3 24-11-2007 06:30 PM
Interesting ! godsownman QnA (read only) 17 24-03-2005 09:00 AM
Unusual,but interesting< problem with LINUX! Akash Verenkar Open Source 2 21-12-2004 07:44 AM
One interesting quote tuxfan Open Source 1 10-11-2004 03:02 PM
- by bhaskar
