| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
True Techie
Can anyone suggest me a mobile below 11k range..?
http://www.mytechyard.com/ |
#2 (permalink) |
if you concern more about camera then go with k790i that has excellent 3.2 mega pix camera
for both good music and cam w810i is the best which has good 2mega pix cam like k750i for nokia side 6500 slide or classic is good ones. prices higher than 11k
Give the best, Give up the rest |
#3 (permalink) |
Bad to the bone
Don't look elsewhere and waste your money, just go ahead & pick Motorola's Motoming a1200. It is everything that you can ask for in a cell phone. You should get it for Rs. 10,200.
Twitter: @amitabhishek |
#5 (permalink) |
Techtree Reviewer
If camera performance is important, get SE K790i. If music quality is important, get Nokia 5310. If you want a smartphone get Nokia 5700. For a touch screen phone, get Motorola ROKR E6.
#6 (permalink) |
Bond, Desi Bond!
Camera and music: W810i : Rs.9k
extremely slim and music: nokia 5310: Rs.9.5k Powerful smartphone and music: Motorola E6 : Rs.10.5k Slim music and camera : W610i : Rs.10.2k I bought E6 and if you like modding the phone, this will be the best choice. Nothing comes anywhere near to this phone in terms of performance-per-paisa. |
#7 (permalink) |
True Techie
Thanks guys. If there are other options please let me know.
http://www.mytechyard.com/ Last edited by nithinks; 28-02-2008 at 07:42 AM. |
#8 (permalink) |
The Smaller Bang
moto rokr e6
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#9 (permalink) |
Sangeet Premi
If possible, add 1K to your budget and get a Nokia 5610. Its around 12K these days.
If budget is a constraint, consider W610i, 5310, 5700 in that range. Choose acc. to your requirements |
#10 (permalink) |
True Techie
Can I compare the features of cellphones in some website? it would be great if someone can give me the link
#13 (permalink) |
6500 slide is also a good choice if you can afford
http://europe.nokia.com/A4423143
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| suggest the mobile | jammer | Buying Advice | 15 | 15-01-2008 06:12 PM |
| suggest tke best mobile | i4u | Buying Advice | 2 | 10-01-2008 06:47 PM |
| suggest a mobile for 13k | zodyac | Buying Advice | 47 | 08-05-2007 07:07 AM |
| Plz Suggest a Mobile | Sankalp | Buying Advice | 24 | 08-07-2006 09:42 AM |
| Suggest a Mobile under 6K. | ~Phenom~ | Buying Advice | 12 | 18-01-2006 10:13 PM |
