Old 21-01-2008, 09:37 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default suggest me a good mobile phone at 10k
One of my friend is looking for a new mobile at around 8 to 10K,, he had a confusion between nokia and sony ericsson ...
can any body suggest me here a good hand set within this range....?
well if i have to chose one from the following set,, which will be better... and why...?
nokia 6233 ,5310, 5700,
sony ericsson w700i, w810i,w580i
please reply fast...
My TeCh Blog: Gtechinfo
>> http://gtechforall.blogspot.com
Mobile Blog : Gtechmobiles
>> http://gtechmobiles.blogspot.com
gau_pppu is offline
Old 21-01-2008, 09:54 AM   #2 (permalink)
sandeepkochhar's Avatar
Default Re: suggest me a good mobile phone at 10k
It purely depends. If your friend wants to buy a music phone nothing beats SE Walkman series, a camera phone SE cybershot series, software applications for mobile then go for Nokia Symbian based mobiles...
No matter where you go, there you are...
sandeepkochhar is offline
Old 21-01-2008, 10:10 AM   #3 (permalink)
gau_pppu's Avatar
which one will you chose from the above mentioned hand set...
give your view for a general purpose....considering all +ve and -ve side from both SE and NOkia
gau_pppu is offline
Old 21-01-2008, 10:13 AM   #4 (permalink)
New
New's Avatar
W810i is the best mobile that you can get for 10k .
New is offline
Old 21-01-2008, 10:36 AM   #5 (permalink)
sony erricsons battery back up....is poor.....IS IT TRUE?
If Nokia's 6233 (MUSIC EDITION) is compared to 810i , which will be a better option???
abcd007 is offline
Old 21-01-2008, 10:42 AM   #6 (permalink)
gau_pppu's Avatar
Exactly what "abcd007" said...!
i also want to know that if had to compare between nokia 6233 and w810i considering +ve and -ve side of bot the hand set, which will be better ...
i know as far as battery power in concerned nokia is better than SE..
but what abt the others.....?
gau_pppu is offline
Old 21-01-2008, 11:53 AM   #7 (permalink)
Rockstar11's Avatar
6233
+ 320x240 screen, larger, daylight readable in full sunlight
+ stereo speakers that sound richer (really good sound )
+ better, bigger keypad buttons to type on
+ 3G
+ microSD card (compatible with many SD cameras and devices)
+ 640x480 video recording
- Poorer MP3/Video playlists, no FF/RW through a video/song.
- No flash for camera.
+ Flash updates from only Nokia that's easy to install; otherwise, have to get 3rd party cable, software, firmware to update - not as easy as the Sony 3rd party providers.
+ Bigger screen and resolution allows for better web browsing experience.
+ Easy copy and paste of text from one place in the phone to another.
++ Full security locks that can be turned on. Phone can be set to require key code before you can do anything when powered on.
W810i
+ smaller & slimmer
+ MS Duo slot (compatible with PSP, digicams, etc from Sony)
+ Brighter backlight on the superb looking screen - like a Samsung D600, albeit lower resolution.
+ Auto backlight brightness adjustment.
+ More audio speaker/headphone accessories from Sony, including docking station.
+ Longer battery life.
+ Built in AF camera with flash/flashlight feature.
- 17?x12? whatever, something really chunky and poor for video recording - you don't even wan't to use it. yuck!
- slightly Neurotic navi/menu buttons. Confusing for non-Sony users, and not as fast to navi with vs. Nokia/Samsung buttons. Menus are also more 'complex' and harder to navi as fast, IMO. Esp. so blind (ie. menuing w/o looking).
+ Flash updates from Sony as well as two commerical servers that work well.
-- No security locks when powered on! Can't lock the phone with security code when it's on to prevent misuse if left on a desk and/or lost!!
Nokia 5700 good all-rounder phone
Rockstar11 is offline
Old 21-01-2008, 12:07 PM   #8 (permalink)
a_k_s_h_a_y's Avatar
i had the same budget of 10k ..! and i got k550 .. now its a k550 @ w610
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 21-01-2008, 02:24 PM   #9 (permalink)
yes i will also recommend k550i
good for both camera and music though it is k series phone
it is cybershot tagged phone
check these before buying it especially its keypad
http://www.sonyericsson.com/cws/prod...0i?cc=us&lc=en
Give the best, Give up the rest
choicefreedom2000 is offline
Suggest me a good phone kanewilliam Buying Advice 11 01-02-2008 11:16 AM
Suggest me a Good Phone.. sakthirajesh Buying Advice 6 05-12-2007 11:04 PM
Suggest a good phone under 10k n2casey Buying Advice 16 31-07-2007 06:00 PM
Suggest me a good phone within 25k Pravas Buying Advice 13 09-05-2007 08:08 AM
suggest a phone for using Mobile Office in good speed Tech.Masti Buying Advice 10 31-01-2006 06:54 PM
- by bhaskar
