Old 21-01-2008, 12:55 AM   #1 (permalink)
a_k_s_h_a_y's Avatar
Cool good phone for 20k
budget is 20k.. possible extend to 25k
needed is only features and features and more .nothing else
which is the phone ??
N82 or N95 ??
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 21-01-2008, 01:01 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: good phone for 20k
n82 imo
Pathik is offline
Old 21-01-2008, 01:07 AM   #3 (permalink)
sure.. i hope it won't disappoint.. !
wht's the price for n95..
doesn't the N95 beat N82 ??
Old 21-01-2008, 01:21 AM   #4 (permalink)
Rockstar11's Avatar
only features ??? nothing else?? sure??
go for N82
lagta hai ab Nokia Flashing, Modding, Patching, Hacking....... hogi
Rockstar11 is offline
Old 21-01-2008, 02:07 AM   #5 (permalink)
go for N82, flash it to N95-8GB. so u get 8GB oodles of space. then mod it with the iphone screen. Voila, there u get a 2.8" screen. hack the Apple iphone interface. n u have the multi-touch user interface.
imagine all for 22k bucks.hehe..lol.
ok, seriously, i would suggest the N82, if features are all u want.
if u wanna save some bucks n cud compromise on 3G, Wifi, then Samsung G600 is the way to go. 17k. n u get sum really gud features , n de unique fm radio recording. though much useful.
apacheman is offline
Old 21-01-2008, 08:01 AM   #6 (permalink)
=--=l33t=--=
ring_wraith's Avatar
+1 n82. Best camera ever, it even has 128MB of RAM for God's sake.
Homer: God bless those pagans.
ring_wraith is offline
Old 21-01-2008, 03:58 PM   #7 (permalink)
for camera and videos n82 is the best compare to other phones in its range
including N95 and N95 8GB
it other features are also very good
take a look here
http://www.nseries.com/products/n82/#l=products,n82
Give the best, Give up the rest
choicefreedom2000 is offline
Old 21-01-2008, 04:42 PM   #8 (permalink)
Net007
Posts: n/a
Go for N82.
Old 21-01-2008, 04:50 PM   #9 (permalink)
Cool G5's Avatar
Go for N82.
But if you are ready to spend Rs.30K,then N95 8GB.This is sure a great phone.
Cool G5 is offline
Old 21-01-2008, 07:49 PM   #10 (permalink)
ashfame's Avatar
N95 8GB is now available @ 22k
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 21-01-2008, 09:12 PM   #11 (permalink)
Rockstar11's Avatar
toh N95 kitne mein milega? 15k ???
Old 21-01-2008, 11:24 PM   #12 (permalink)
AFAIK..N95 GB is priced at 29k..
and N95 @ 22K
/<u/\/@L...
SHuD i wRite MoRe..
All hail Arsenal...
Gunner 4ever...
kuni5_hem is offline
Old 22-01-2008, 12:16 PM   #13 (permalink)
Cool G5's Avatar
Cool Re: good phone for 20k
The one you are talking is the old N95 4GB having 2.6 inch screen.It is priced at Rs.22K.
The new N95 8GB having 2.8 inch screen,1200mah battery is priced at some Rs.30K.
Cool G5 is offline
Old 22-01-2008, 12:24 PM   #14 (permalink)
sandeepkochhar's Avatar
Good phone for 20k is Sony Ericsson P1i...Period...
No matter where you go, there you are...
sandeepkochhar is offline
Old 22-01-2008, 05:26 PM   #15 (permalink)
friend_sunit's Avatar
in 20K u can get the HTC Touch..
and may be the iPhone too
www.CorpoAlert.com
http://sms.gizmodise.com
friend_sunit is offline
Old 22-01-2008, 09:08 PM   #16 (permalink)
M$™ Certified Spammer
entrana's Avatar
try sony k850i. it rocks!
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Is there a good phone without Cam? alib_i Mobiles and Tablets 10 18-12-2007 06:43 PM
Suggest me a Good Phone.. sakthirajesh Buying Advice 6 05-12-2007 11:04 PM
T610 is a good phone or not? cooldudie3 Mobiles and Tablets 10 16-08-2007 02:01 PM
Suggest me a good phone within 25k Pravas Buying Advice 13 09-05-2007 08:08 AM
A Good GSM phone under 15k desh2s Buying Advice 27 24-04-2007 10:10 AM
- by bhaskar
