Old 12-01-2008, 01:14 PM   #1 (permalink)
Default Is buying an unlocked iphone with the latest firmware wise?
i'm in dire need of the iphone. is it safe enuff to buy an unlocked version here
in india? or if i ask sum1 to get it frm US n get it unlocked here will it get unlocked even after being revised with the lastest firmware?as i heard they've blocked the unlocking stuff too.
n how much will it cost if i get it frm grey market here? will it be a sealed and guraranteed one?
apacheman is offline
Old 12-01-2008, 01:39 PM   #2 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default Re: Is buying an unlocked iphone with the latest firmware wise?
not sealed, not guaranteed.
I say wait.
ring_wraith is offline
Old 12-01-2008, 08:35 PM   #3 (permalink)
Pat
Member of Apple Family
Pat's Avatar
Get it from the US if you are ready to wait to use the "phone" functions (makin/receiving calls,sms,gprs etc) for a month or so..Till then you will be able to use all the other functions..If you cant wait,buy an unlocked on here in India which should set you back by about 25k
Pat is offline
Old 12-01-2008, 10:22 PM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
Lol, can you give us an insight into your dire needs
You may buy it, but there is always a scare that there may be no unlocking, all the unlocking lookholes may be blocked.
www.twitter.com/alsiladka
alsiladka is offline
Old 13-01-2008, 04:53 AM   #5 (permalink)
well, thats (dire need) a pathetic adjective i've used there, it shud've been more like "irresistable desire", "compelling hunger", "craving", "yearning" or "The Urge"!! hehehe... 'its lust'....
Old 13-01-2008, 08:34 AM   #6 (permalink)
hahahari's Avatar
^Dont bother about unlocking.............if the unlocking stops working you can always find other new unlocking methods.but yeah waiting is the best option
www.harivarrier.com
Check out to earn money...
hahahari is offline
Old 13-01-2008, 12:35 PM   #7 (permalink)
napster007's Avatar
wait for a month man. the iphone will release....probably the 2.0 ver. it'll have all the bugs in the current iphone like no video rec, group sms, mms etc fixed
napster007 is offline
Old 13-01-2008, 12:42 PM   #8 (permalink)
The Devil's Advocate
iMav's Avatar
no v2 wont be releasing so soon ... 1 month not a chance el jobso is going to release v2 with a lot of fan fare and it cant be in 1 month
http://beingmanan.com
iMav is offline
Old 13-01-2008, 05:51 PM   #9 (permalink)
can you throw some light on the 'fanfare' stuff? i mean, wot kinda goodies? n when can it be expected, any faintest idea??
Old 13-01-2008, 10:21 PM   #10 (permalink)
Pat
Pat's Avatar
a:> Firmware V2 is not going to happen so soon. (If you are talking abt iphone v2 then theres a long long time for that)
b:> Those are not BUGS..they are lack of features..Hope you understand the difference
Pat is offline
Latest firmware version for 6681 ? cyrux Mobiles and Tablets 10 25-05-2008 07:29 PM
Nokia 6600 latest firmware vimalonline Mobiles and Tablets 4 27-08-2007 03:03 PM
N70 latest firmware arunks Mobiles and Tablets 2 27-11-2006 08:02 AM
K750 - Latest Firmware.. Where it is? steelwin Mobiles and Tablets 1 07-08-2006 10:10 AM
