Old 10-01-2008, 12:28 AM   #1 (permalink)
Arun the Gr8's Avatar
Exclamation plz suggest the cheapest mobile
can u guys help me out..
i need specs of 2 mobiles..
1. cheapest flap colour mobile
2. cheapest mobile with card reader and acceptable music performance
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 10-01-2008, 09:00 AM   #2 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default Re: plz suggest the cheapest mobile
1. W200 - Motorola
2. w200i - Sonyericsson
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 10-01-2008, 06:41 PM   #3 (permalink)
samsung E250
it is nice slider phone and available in many colors
its really a good phone having good Mp3 player, FM radio as well as you can expand your memory with it. and surprisingly it has MicroSD memory card slot
in short all you want to have
but it has just VGB camera. I think I is good to get all this stuff in just around 5k or buy it second hand
get more detail about this phone here
http://www.blueunplugged.com/p.aspx?p=120851
choicefreedom2000 is offline
Old 10-01-2008, 06:48 PM   #4 (permalink)
prasad_den's Avatar
And someone please suggest me a cheap FM phone that costs less than 2K....!!
prasad_den is offline
Old 10-01-2008, 07:38 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ Moto c168?
infra_red_dude is offline
Old 10-01-2008, 08:01 PM   #6 (permalink)
kumarmohit's Avatar
LG Bullet is also good
kumarmohit is offline
Old 10-01-2008, 09:13 PM   #7 (permalink)
prasad_den's Avatar
Thanks.. Will check out both..!!
Old 11-01-2008, 12:39 PM   #8 (permalink)
you can also try Samsung C160 or C170
both looks good
http://www.samsung.com/ph/products/gsm/gsm/sgh_c160.asp
Cheapest PC internet mobile dead Mobiles and Tablets 10 27-12-2007 11:55 AM
Suggest cheapest color mobile int86 Buying Advice 11 06-06-2007 10:06 PM
Cheapest GPRS Class 10 phone with EDGE please suggest ramu Buying Advice 11 03-10-2005 09:18 PM
suggest the cheapest n best digicam esumitkumar Cameras and camcorders 4 11-03-2005 07:06 PM
