Old 11-12-2007, 09:01 AM   #1 (permalink)
Default Suggest: Tough Mobile phone with best reception power
Hello Friends,
Which is Cheapest (Rough & Tough) Mobile phone can hold dual sim (using some adopter cost Rs.25-150) with good battery life & loud ring tone/sound with good signal reception power in low signal area, if have FM will be added advantages.
Just don't suggest over weight modles
Thanks
PS: It's Mendatory for Krazy to post in this thread
Why don't you allow HTML signature?
Stick is offline
Old 11-12-2007, 02:22 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Suggest: Tough Mobile phone with best reception power
I'd suggest Nokia 1112. Compromise a bit on the "roughness and toughness" and you can buy Nokia 2610 (personally I think its looks very ugly!). You can also consider Nokia 6030. The durable color phone with FM (probably the only!)
Stay away from SE and Moto phones in that range, if you want the phone to be very tough!!!
infra_red_dude is offline
Old 11-12-2007, 07:17 PM   #3 (permalink)
SymbianGeek
If you want a tough one - check this out
http://www.nokia.co.in/link?cid=EDITORIAL_401218
--eminemence.
Visit http://flaminghorns.com
eminemence is offline
Old 11-12-2007, 07:34 PM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
I already replied in the prices sticky thread. I don't feel the need to post the same thing here again.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 12-12-2007, 01:56 AM   #5 (permalink)
Please give me url
Stick is offline
Old 12-12-2007, 06:03 AM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
^^ Its on the last page after your post. Did you forget that you posted the same question there too?
krazzy is offline
suggest a ringtone for my new n70 mobile phone arunks Buying Advice 17 14-01-2007 08:37 PM
Plz suggest a Mobile Phone for me gkiran Buying Advice 7 23-09-2006 02:02 PM
A tough call, suggest a phone mayurhastak Buying Advice 3 08-09-2006 01:30 PM
Suggest Mobile Phone sweet.grrll Buying Advice 10 04-09-2006 02:59 AM
SUGGESTIONS : Pls Suggest a MOBILE phone under 8K Vishal Gupta Buying Advice 20 06-04-2006 09:02 PM
- by Charley
