Old 09-12-2007, 10:52 PM   #1 (permalink)
Question Help me buying an entry level phone
I want to buy a new phone with price range upto 3k. Though I dont expect moch but I would like the follwing features to be there:
1. FM radio with good reception, headset socket separate from the charging one.
(with sturdy earphones, normally many go bad just by a mere pull).
2. Stopwatch that would go beyond 59:59.
3. Handsfree speakerphone.
4. Calendar with good memory.
5. Java/Wap.
6. Phone/keypad lock by password.
7. Good menu interface and input method.
8. Large phonebook and SMS memory.
If any phone You know please do tell. I may stretch the range a little bit.
ravi.xolve is offline
Old 10-12-2007, 12:44 AM   #2 (permalink)
In search of light...
abhi.eternal's Avatar
Default Re: Help me buying an entry level phone
motorola w220. it think it fits perfectly (except the interface may be!).
http://abhijeetdeb.com
abhi.eternal is offline
Old 10-12-2007, 08:38 PM   #3 (permalink)
AJJU
azzu's Avatar
^ my frnd has it
if u can get on with that Worse interface its a good deal
or else nokia 6070 3.5k worth the deal
I love and Live to Design
azzu is offline
Old 11-12-2007, 02:24 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
How about Nokia 6030?
If you want a separate connector for headset and charger then low-end Nokia phones are your only choice!
infra_red_dude is offline
Old 11-12-2007, 07:29 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Moto Yuva w180
or 6030
Pathik is offline
Best entry level Laser printer... dip_10 Peripherals 5 28-09-2007 06:19 PM
how is motorola W209? (entry level phone) nix Mobiles and Tablets 4 08-04-2007 02:09 AM
Entry Level Scanner-Printers xpabhi Peripherals 3 01-11-2006 11:46 PM
Entry Level Scanner??? Urgent Aseem Nasnodkar Peripherals 4 05-05-2006 08:05 AM
Entry Level Graphic Card naveenpoddar Graphic cards 6 12-03-2005 02:24 PM
