Old 08-12-2007, 06:39 PM   #1 (permalink)
Troubleshooter
Question Problem with WM6.0 Standard
I bought an HTC S710 recently.
As soon as I switched on the phone, it got all the settings by itself from Airtel, GPRS, MMS, etc and installed them automatically in the required places and Internet Explorer Mobile worked out of the box right away.
When I was figuring out how to use the phone as modem on the PC, I referred the owners manual and it says click Start -> Internet Connection Sharing. There is no Internet Connection Sharing in the Start Menu. I didn't find it in any of the sub menus as well.
Where is it hidden in Windows Mobile 6.0 Standard?
deepakchan is offline
Old 08-12-2007, 08:10 PM   #2 (permalink)
!FREEWARES!
Akshay's Avatar
Default Re: Problem with WM6.0 Standard
Go to start - programs - internet sharing
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is online now
Old 08-12-2007, 09:00 PM   #3 (permalink)
Google Bot
Pathik's Avatar
@deepak are u using Mo or NOP??
Pathik is offline
Old 08-12-2007, 10:34 PM   #4 (permalink)
D PrankMaster
prankie's Avatar
goto
start--> settings-->connections
there'll u'll find connections icon
open it and goto manage existing connections, select ur operator setting if u want to make any neccesary changes..
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 10-12-2007, 06:57 AM   #5 (permalink)
Troubleshooter
I'm using MO. There is NOP anymore in Chennai
I've found Internet Sharing. Its under Start -> Applications -> Internet Sharing.
will try connecting now as per the owners manual and report back.
USB Connection is working like a breeze now. No need to do anything on the PC. Just connect the usb cable and click connect on the phone. It automatically creates a "Local Area Connection 2" on the PC and gets connected to the net.
Next thing I am trying to figure out is how to connect via Bluetooth and use the phone as modem. It is a little complicated to me. Have to set up Bluetooth PAN Network and all. Haven't done it till now. Any help with that?
I have another doubt. All the sent items in Text Messages, I have to delete one by one? There is no way to clear the Sent Items right away?
Standard TCP/IP printer port Problem muthiya2000 Software Q&A 2 02-10-2007 07:16 PM
Getting standard XP icons back. djmykey Software Q&A 1 16-03-2007 10:53 PM
PDF to become an open, ISO standard praka123 Technology News 4 30-01-2007 11:26 AM
Maxthon Standard 2.0.0.6363 is out. anandk QnA (read only) 2 13-08-2006 03:43 PM
32 bit or 64 bit is standard? varunbhide QnA (read only) 1 09-08-2006 01:08 PM
