View Poll Results: Which one should be opted for? (pls post details also)
Nokia 5700 8 36.36%
SE w810i 11 50.00%
Moto E6 3 13.64%
Voters: 22. You may not vote on this poll
Old 12-11-2007, 06:10 PM   #1 (permalink)
~It_is_Andrew~'s Avatar
Default need suggestions on mobile purchase ( newbie in cells) !
Hi,
I am planning to buy a cell, for last few years I have been using a 1108 which was also my first cell phone..... so you can very well guess that I am not one of the guys with lots of mobile funda
Used the phone extensively for its basic original purpose i.e. to make calls & sms
Now if i buy a new mobile I wanna buy a moderately good one -
1) Ofcourse to make calls - I always call from cell even when I have landline around.
2) Will use it a lot for listening to music & video
3) Should be good enough cam for occasional snaps,
4) Should be hardy enough for my rough use.
primarily my budget was upto 8k but extended it to 10k.
I have browsed this forum & narrowed down to a few - namely SE w810i , MOTO E6, nokia 5700. dDonno if I missed any good one.
Basically I am a nokia fan but willing to try out others & hope not making a mistake.
(also i would like to know whats the current market price for 4GB MSPD)
So please suggest & help out this newbie (in cellphones) to make a good decision.
Regards,
~It_is_Andrew~
~It_is_Andrew~ is offline
Old 12-11-2007, 07:17 PM   #2 (permalink)
respect mah authoritah!!
girish.g's Avatar
Default Re: need suggestions on mobile purchase ( newbie in cells) !
5700 for symbian
w810 for music
rokr e6 for customisability
girish.g is offline
Old 12-11-2007, 07:17 PM   #3 (permalink)
New
New's Avatar
Go for W810i.. nice phone with good sound.If you want go for 5700
New is offline
Old 12-11-2007, 07:30 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Nokia 5700.. Once u get a high end fone and activate gprs on it, u ll be hooked
Pathik is offline
Old 12-11-2007, 08:35 PM   #5 (permalink)
hmmmm..... I'm getting even more confused.......
A bit details please?
(also i heard w810i cant read pdfs/docs in a easy way)
Old 12-11-2007, 11:06 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
8k? Decent Cam, sturdy, nokia fan, need to open PDF files? Look no further and get Nokia 5500. The only place where you compromise is the screen size.
Its true that you can't open PDF files in W/K Series SE phones (except W950, W910 and W960i).
infra_red_dude is offline
Old 12-11-2007, 11:12 PM   #7 (permalink)
You gave been GXified
gxsaurav's Avatar
Why not Nokia E50/E51
about.me/gxsaurav
gxsaurav is offline
Old 12-11-2007, 11:20 PM   #8 (permalink)
Thanx for the replies...
@infra_red_dude,
ya my primary budget was 8k but i am willing to spend more till 12 max if it worth it, thats why considered e6 & 5700 besides w810i
5500 is a bit older model isn't it?
I was seriosuly considering w810i but then these 'lack of support for playing other formats & softwares' got me into thinking..... (I would not mind modding, though I need to know much.....)
Old 12-11-2007, 11:29 PM   #9 (permalink)
Ganeshkumar's Avatar
Should be hardy enough for my rough use.....
E6 fails here
Ganeshkumar is offline
Old 13-11-2007, 05:49 AM   #10 (permalink)
vasulic's Avatar
go for n73 its 13.4k in grey market
vasulic is offline
Old 13-11-2007, 08:44 AM   #11 (permalink)
r2d2's Avatar
Go for the n91 8gb, the ultimate music phone (at least sound quality wise), its symbian series 60 based and to top it all it only cost about Rs. 11000.
r2d2 is offline
Old 13-11-2007, 09:38 AM   #12 (permalink)
ArZuNeOs's Avatar
no kidding man Rs 11000 for n91 8gb.....huh this aint april yaar
Back to the world of realms
ArZuNeOs is offline
Old 14-11-2007, 02:17 AM   #13 (permalink)
r2d2's Avatar
http://www.thinkdigit.com/forum/show...378#post642378
IIRC, i saw that price in www.wavetelmobiles.com too, but page is no longer there.
r2d2 is offline
Old 16-11-2007, 01:09 AM   #14 (permalink)
Thanx for all your replies ..... I almost decided going for SE w810i BUT -
I needed a very little insignificant feature of 'automatic keypad lock with password' which was not present in w810i & patching seemed all hebrew with different CIDs & patches not being available for all......(maybe someone can throw some light) ... & also support...
Its funny actually how much I would like that simple basic feature
So now I am thinking of going for a nokia with symbian OS.
1)So please suggest nokia(or ?) phones with recent symbian os preferebly in the price range of w810i yet upto 12k (maybe first & second choice) - hopefully they should support memory expansion of atleast 2 GB upto 4 GB
2)Does any of them have autofocus?
3) or any other suggestion you might wanna give even with w810i
Please reply.
Thanks & Regards,
~It_is_Andrew~
Old 16-11-2007, 01:52 AM   #15 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
w810 has Autofocus , and i think none other have in the list . also the 'automatic keypad lock with password' feature is activated on my phone with just one patch , i have the patch for R1BC002 as
keylock_password_w800_r1bc002.vkp
R4EA031 might be the firmware you will get
i have Patch for that one too .
if you buy w810 i will help you in putting the patch . it is piece of cake (ut voids warrenty)
R4EA031 : 2006-09-25; Java version upped to 6.5
R4DB005 : Latest available available for SEUS; first documented 20-June: MR1
R4CM001 : first documented 9-June
R4CK003 : flashing bug fixed; camera version remains at 4.5; dropped calls problem for some operators fixed
R4CF002 :
R4CE012 : release version
R4CA026 : pre-release version
File Type: zip keylock_password_w810_r4ea031.zip (491 Bytes, 3 views)
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 16-11-2007, 10:36 AM   #16 (permalink)
Techtree Reviewer
krazzy's Avatar
You can go for Nokia 5310 Xpress Music. It has automatic keypad lock among other features. Or you can buy 5700. Automatic keypad lock can be enabled in this phone by simply installing a software.
krazzy is offline
Old 16-11-2007, 10:56 AM   #17 (permalink)
Cool G5's Avatar
Look no further than Nokia 5700.
Pros:
#Latest symbian os 9.2 Feature pack 1
#Fastest processor on a nokia ever
#Good signal reception
#Good keypad for SMS typing.
Cons:
#Slight hard joystick
#Camera has no Autofocus.
Cool G5 is offline
Old 16-11-2007, 12:28 PM   #18 (permalink)
Thumbs up Re: need suggestions on mobile purchase ( newbie in cells) !
i've been using w810i from past 3 months.. i got w810i after much reseaech on this forum and other places... u'll get great music and great cam at reasonable price ... the only prob is battery life it'll be dead with in 2 dayz... go ahead with 810 ...
rahuld is offline
Old 16-11-2007, 03:30 PM   #19 (permalink)
Techtree Reviewer
krazzy's Avatar
^^ I don't think thats a problem. 2 days is quite acceptable.
krazzy is offline
Old 19-11-2007, 12:24 AM   #20 (permalink)
Few last things...
1)could anyone provide any 'how to' to install java utility apps on w810i
2)Is w810i is a good enough phone for web bowsing (mainly email checking & little chatting & googling)?
3) Some say it support only upto @GB memory , some say it does up to 4GB , some say it does up to 4GB but most of the time freezes when 4GB is inserted. whats true?
4) How is the SE support? (in kolkata?)
will it be a better idea if i buy through 'themobilestore' - it seems they sell at higher price!?
Old 19-11-2007, 01:11 AM   #21 (permalink)
Wire muncher!
You simply drag and drop the java App/Game in the Others folder in Phone or memory card and then open it from within phone to install.
That should be fine. But if you wanna surf wid more real estate you may wanna check out other models with bigger screens.
The phone supports Memory stick pro duo cards upto 4GB without any problems. 8GB support is not confirmed.
SE provide decent support here in Bangalore. Someone from Kolkata may answer this specific Q.
Old 20-11-2007, 09:56 PM   #22 (permalink)
thanx for the reply ....
anyone may know about the support & shop thing?
Is there any java app for w810i which supports password protecting the inbox? (i tried searching but none yet)
I have almost decided on w810i ( )though its an old model ( ) & not sure aboput the password soln ( )
Old 21-11-2007, 01:14 AM   #23 (permalink)
Wire muncher!
NO. There is no password support for Inbox (native or thru app).
Old 24-11-2007, 11:07 AM   #24 (permalink)
I heard a lot about the hissing sound in w810i at low volume & the poor battery backup.... any insight about that?
Old 24-11-2007, 12:53 PM   #25 (permalink)
Wire muncher!
^^^ No problems regarding that. It was there in older firmware. The newer ones don't haf this problem. Don't worry
Plus once you get your hands on W810i you can jus hack into it to do wonderful things
Old 25-11-2007, 12:18 AM   #26 (permalink)
ok finally i got the time to visit a few shops....
Almost all of them tried to convince me that SE phones are no good as they are not user friendly , hangs & terrible battery.....
one guy argued a lot in favour of nokia 5310 ( so what do you guys say?)
The price thread in here says that w810i are prices at 9.3 k but the two shops in kolkata including nikkys quoted 10.5k for it.
themobilestore selling it for ~9.8k but without the MPS 60 speaker.
so what should i do? Is not getting MPS 60 to save few bucks is good?
Are the prices ok or should i look for a better deal?
If anyone is from kolkata & knows any good shops please recommend so....
Thanks for keeping replying guys... waiting eagerly for some more inputs.....
Old 25-11-2007, 02:05 PM   #27 (permalink)
Jack of all Trades.
i think it supports upto 2gb card only better u consider d mannuals of ur phone
paradisevikas is offline
Old 25-11-2007, 08:40 PM   #28 (permalink)
ummm thanx for the reply paradisevikas
sorry for prolonging this thread .......but anyone to with any inputs for my last worries? please!
Old 26-11-2007, 08:58 PM   #29 (permalink)
come on yaar no reply help me out...........
Which mobile connection will be best to purchase in bhubneshwar ORISSA for 2 months arunks Buying Advice 1 05-10-2007 10:19 PM
Buying a mobile.?? .Get SUGGESTIONS here..!! akshaykapoor_3 Buying Advice 7 17-05-2007 08:27 AM
Precautions during purchase of Old mobile ? sainit Mobiles and Tablets 9 14-03-2007 11:35 PM
Suggestions for a new mobile-cum-pda? physri Buying Advice 3 01-06-2006 01:10 PM
I want to purchase a mobile. NikhilVerma Mobiles and Tablets 14 08-11-2004 09:25 AM
- by bhaskar
