Old 28-09-2007, 05:45 AM   #1 (permalink)
jatt's Avatar
Question micro sd card problem
my micro sd card is not working it stops working i don't know what s the reason when i insert it in my nokia 3110 it gives message its not formated do you want to format after pressing yes button it gives message again card is formated but it is not opening i also tryed it on my pc but not able to open it when i tried to open it stops.not gives any respons i could'nt able to format it is it mean that my card goes corrupted please take me out from this confusion thanks friends
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 28-09-2007, 08:54 AM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: micro sd card problem
As my eXperiance the card is corrupted go get a new 1
I love and Live to Design
azzu is online now
Old 28-09-2007, 09:11 AM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Another thing you can try with your pc through card reader. Right click on my computer>Properties>Manage>Disk management and see whether the SD card shown there. If the format option is enable try that.
Also if the SD Card mfg has any repeir tool try to search with google, if found try with that.
Before purchasing a new one wait for a day. lets see any solution comes for any of our member.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Micro SD card problem ratedrsuperstar Buying Advice 9 18-08-2007 06:12 PM
Help needed for micro SD card mahip7 Hardware Q&A 5 07-08-2007 06:01 PM
Micro SD memory card JohnephSi Mobiles and Tablets 5 26-06-2007 02:30 PM
Diff between MS Pro Duo & Micro?? hareesh Mobiles and Tablets 2 26-11-2006 12:23 PM
My new Creative Zen Micro 5GB grooveman Software Q&A 6 12-05-2005 03:49 PM
