Old 05-09-2007, 09:38 AM   #1 (permalink)
damn busy...
utsav's Avatar
Question suggest a good cdma phone under 3k
my tata phone recently got damaged and i need a phone temporaily so i am not investing much in it.my sim card is ok.so plz suggest a CDMA phone under 3k .FM not required.and i want internet connectivity to use it on my pc if possible.
plz help
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 05-09-2007, 11:02 AM   #2 (permalink)
New
New's Avatar
Default Re: suggest a good cdma phone under 3k
Go for 1600..OR Go for 6030..
New is offline
Old 05-09-2007, 11:23 AM   #3 (permalink)
Call me Sumit
esumitkumar's Avatar
he is asking for CDMA and u r giving GSM
well go for hero samsung set 1500/- cheap n gud
esumitkumar is offline
Old 05-09-2007, 03:13 PM   #4 (permalink)
damn busy...
utsav's Avatar
today i saw an ad of an internet enabled phone for 1.7 or 1.9k .
i want an internet capable phone
someone help plz.its urgent
www.techjunkiez.com
utsav is offline
Old 05-09-2007, 10:08 PM   #5 (permalink)
Troubleshooter
just go to one of the tata indicom hubs in the city.. choose one that fits your budget.. you may come across something which you like even if you have made up your mind on something.. preferably stick to nokia / samsung for easy warranty issues..
deepakchan is offline
Old 05-09-2007, 10:36 PM   #6 (permalink)
damn busy...
utsav's Avatar
i wanted a suggestion regarding the phone model then only i would go to the HUB for more details
www.techjunkiez.com
utsav is offline
Old 20-03-2008, 11:06 AM   #7 (permalink)
All,
I have recently purchased a Huawei c5320 cdma Handset. Problem is my Phonebook on my computer is in a .csv format. Any idea about how I can convert the same to the .dat format (recognised by Huawei)? Please help as in the alternative, I would have to manually enter the whole phonebook!
Regards,
Rahul
rahuldonde is offline
Old 20-03-2008, 01:34 PM   #8 (permalink)
damn busy...
utsav's Avatar
can you post here any demo .dat contacts file and demo csv contact file .i may help you then to do the conversion
www.techjunkiez.com
utsav is offline
Suggest a good phone under 10k n2casey Buying Advice 16 31-07-2007 06:00 PM
Suggest me a good phone within 25k Pravas Buying Advice 13 09-05-2007 08:08 AM
Suggest Me A Good Looking Slider Phone For 15k cutecat4all Buying Advice 12 17-01-2007 09:08 AM
Suggest me a Good Phone sakthirajesh Buying Advice 10 07-12-2006 02:22 AM
- by bhaskar
