Old 20-08-2007, 11:27 AM   #1 (permalink)
Guy from Heaven
Tech$oft's Avatar
Arrow Opera mini 4 beta problem
Opera mini i just downloaded 2 weeks before and i used it , it is giving good browsing speed but there are some problems while accessing site .For e.g Sites like thinkdigit ,orkut ,fropper,dotsis
I can't login digit from this version of opera and i can't reply to scraps in orkut which i can do on opera mini 3.2 stable version
There is some ajax script problem
Could u suggest some solution for this
Tech$oft is offline
Old 20-08-2007, 11:36 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Opera mini 4 beta problem
Nope opera mini 4 supports very basic js.... and there is no solution for it..
Pathik is offline
Old 20-08-2007, 11:40 AM   #3 (permalink)
Guy from Heaven
Tech$oft's Avatar
But how Opera mini can access and login Thinkdigit
Bytheways thanks
Tech$oft is offline
Old 20-08-2007, 01:53 PM   #4 (permalink)
Google Bot
Pathik's Avatar
yup thinkdigit works perfect with opera mini... just the quick reply may give probs sometimes..
Pathik is offline
Old 20-08-2007, 03:01 PM   #5 (permalink)
Cool G5's Avatar
Post Re: Opera mini 4 beta problem
Sorry @tech$oft to hijack thread.
@Pathiks->I am facing a problem in opera mobile 8.65.I can't access sites like thinkdigit,linux forums(forums sites).It gives a XML parsing error.
Plz help on this one.
Cool G5 is offline
Old 20-08-2007, 03:16 PM   #6 (permalink)
Guy from Heaven
Tech$oft's Avatar
Smile Re: Opera mini 4 beta problem
i can only access digit site from opera mini 3.2 and also can login but can't login from opera mini 4 suggest some solution
Tech$oft is offline
Old 20-08-2007, 03:30 PM   #7 (permalink)
Google Bot
Pathik's Avatar
@cool g5 r u using nop or mo? This error comes only in nop..
@techsoft wat error do u get wen u try to login?
Pathik is offline
Old 20-08-2007, 10:46 PM   #8 (permalink)
Cool G5's Avatar
@pathiks->I use NOP.
I will post the error screenshots later.
Cool G5 is offline
Old 20-08-2007, 11:10 PM   #9 (permalink)
Google Bot
Pathik's Avatar
nope that wont matter... evy1 gets errors on NOP...
Pathik is offline
Old 20-08-2007, 11:25 PM   #10 (permalink)
Guy from Heaven
Tech$oft's Avatar
wen i try to login thinkdigit from opera mini 4 , it can't login just refreshes the page
Tech$oft is offline
Old 21-08-2007, 12:26 AM   #11 (permalink)
Google Bot
Pathik's Avatar
very powerful cache u got then.. Do 1 thing enable cookies, login, delete cache, refresh page..
Pathik is offline
Old 21-08-2007, 12:56 AM   #12 (permalink)
the man who sold d world
raina_rocks's Avatar
haha........all d ppl wit nop n mo suffer d same prob ..........
even mozilla n ie do d same as opera does.....its no diff....
Softwares r like sex,
they r better wen they r free!!!
raina_rocks is offline
Old 21-08-2007, 09:27 AM   #13 (permalink)
pushkaraj's Avatar
@Tech$oft, i am facing the same problem in opera mini 4 beta. But i was surprised when i found this out. When you log into digit, although the page simply gets refreshed, you have actually logged into digit. If you don't believe me, you can try this. Just log into digit. The page will get refreshed. Now, just click on some post. And the page that will get loaded will have
Welcome Tech$oft
at the top of it which means you have successfully logged in. Do try this
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 21-08-2007, 09:57 AM   #14 (permalink)
Google Bot
Pathik's Avatar
^ yup thats bcos opera mini has a very powerful cache.. U can also follow my last post..
Pathik is offline
Old 21-08-2007, 11:02 AM   #15 (permalink)
Guy from Heaven
Tech$oft's Avatar
Thumbs up Re: Opera mini 4 beta problem
Thanks to u all , i will try the method u told
Tech$oft is offline
Old 21-08-2007, 12:38 PM   #16 (permalink)
pushkaraj's Avatar
@pathiks, yeah, actually wat u said is absolutely right. The cache is fast.
Old 21-08-2007, 10:05 PM   #17 (permalink)
Cool G5's Avatar
Question Re: Opera mini 4 beta problem
Then,how it(opera mini) works on my friends N70ME & SE K750i?
Both my friends use airtel NOP.
Cool G5 is offline
Old 21-08-2007, 11:10 PM   #18 (permalink)
^^ it works even on ma pc........ but smtimes u may face such probs..... n tats coz u r using nop or mo....
Old 21-08-2007, 11:21 PM   #19 (permalink)
Google Bot
Pathik's Avatar
yup.. Thats a very confusing.. Nop works good for some cell+browser combos only
Pathik is offline
Old 21-08-2007, 11:34 PM   #20 (permalink)
^^^ true....... v3i + mo seems 2 b d best.......
n91+ mo worst........ n communicator+mo gud...
Old 21-08-2007, 11:53 PM   #21 (permalink)
Google Bot
Pathik's Avatar
actually MO works good wit evy fone out there.. Bloody NOP causes probs..
Pathik is offline
Old 22-08-2007, 12:01 AM   #22 (permalink)
^^^ u use nop kya???
Old 22-08-2007, 12:23 PM   #23 (permalink)
Cool G5's Avatar
MO is Rs.7/day.
Is there any plan for mobile office from airtel.I mean Below Rs.150.
Cool G5 is offline
Old 22-08-2007, 09:40 PM   #24 (permalink)
^^^ ya its nop ..... 2 rs /day....
Old 22-08-2007, 09:52 PM   #25 (permalink)
Cool G5's Avatar
I know that.
I mean i want a plan which gives me to browse all sites only my mobile & i won't be using it on pc.Coz my nop doesn't render most of sites correctly.
I find Rs.7/day too costly.
Cool G5 is offline
Old 23-08-2007, 03:20 PM   #26 (permalink)
pushkaraj's Avatar
Unfortunately there is no such offer currently available.
Old 23-08-2007, 09:40 PM   #27 (permalink)
bad news guys..........
airtel mo rates increased frm 7 rs / day to 14.99 rs / day.........
i got d message 2day......n its confirmed......
in effect frm 27th aug...
Old 17-09-2007, 01:27 PM   #28 (permalink)
Guy from Heaven
Tech$oft's Avatar
Angry Re: Opera mini 4 beta problem
Im using k750i and using opera mini 4 beta 2 from 1 week and facing a problem of high memory . My phone shows a error that this application uses too much memory when i minimize it or when it becomes slow . Can anyone suggest me wid a memory booster software or provide a solution for it .
Tech$oft is offline
Old 17-09-2007, 03:05 PM   #29 (permalink)
Cool G5's Avatar
Memory boosters are good for nothing.They do not help much.
If possible disable images,it will save on ram.
Cool G5 is offline
opera mini 4 beta digit i am thinking Mobiles and Tablets 2 23-07-2007 08:04 PM
opera mini v4.0 beta rockzzz anshul Mobiles and Tablets 2 28-06-2007 07:44 PM
Opera Mini 4 beta out now gxsaurav Technology News 15 25-06-2007 03:55 AM
Opera Mini 4 Beta is out! Gigacore Technology News 2 24-06-2007 02:23 PM
